Old 04-24-2013, 03:08 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Rust strikes
So rust has struck my car. Both doors are affected. Seems like stone chips or something that has developed in the mid door gap between the panels. I belive the lower panel is some plastic?
This is pushing the repaint plans a bit.
Subject to closer inspection, should I just get two new doors since I'm having a repaint anyway?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-24-2013, 08:50 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: Rust strikes
The description sounds like rust from the metal clips that attach the lower plastic panel. It shows up along the top edge. May be worse rust behind the panel.
Gene
Gene and Ben
Old 04-24-2013, 09:27 AM
jetboy's Avatar
Re: Rust strikes
Gene
By the clips indeed. Is it actually possible to get rid of the rust or should I start looking for new doors?
Also, I've inspected these areas regularily and it appears to have come overnight.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-24-2013, 10:31 AM
dcarrb dcarrb is offline
Re: Rust strikes
Remove the interior door panels, peel back the plastic sheeting, and have a good look at the doors from the inside. Only then will you really know what you're up against.
dcb
Old 04-24-2013, 12:17 PM
SVX_MY_BABY's Avatar
Re: Rust strikes
I agree with the advise given. If you are just seeing it it may not be too bad but don't leave it. Also be sure that the body shop knows the correct procedure for removing the plastic outer lower panel so they don't cause it to be bent or warped. Instructions are in the OEM manual available from this site.
Peter
Old 04-24-2013, 02:59 PM
jetboy's Avatar
Re: Rust strikes
Good advise, I'll get onto it "fairly soon".
Parts take me a good week or so in shipping. Any clips or anything that will break with this procedure that I can just order immediately?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-24-2013, 04:58 PM
bwb3's Avatar
Re: Rust strikes
This image from SubaruParts.com is a bit confusing but, at minimum, you might need parts 3 through 7. Comments?
Gene
Gene and Ben
Old 04-25-2013, 01:03 AM
jetboy's Avatar
Re: Rust strikes
I assume the same drawing will be on opposedforces Thanks.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-29-2013, 07:11 PM
Green1995SVX's Avatar
Re: Rust strikes
This is just so common on our cars. Even at just 40k miles, mine was suffering from the same affliction. Below are some pics with the plastic cladding removed before I began its restoration.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-29-2013, 07:39 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Rust strikes
Id hate to see what my doors look like after I take the cladding off, thats why I bought a set of rust free doors, or so I think. No visible rust or bubbling to be seen, but who knows what lies beneath the claddings. Mike did you use bondo on those rust holes or cut out new metal.
1995 POLO LSI 76K MILES SOLD
