Old 03-29-2013, 06:08 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Belts recommendations?
My belts always squeal at low rpms. I bought new belts, checked the fluids, tightened the tensioner, but the belts seem to slip. I use belt dressing and it helps for awhile. Are there different types of belts that are better than others? Any recommendations? Or maybe I should try different pulleys?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 03-29-2013, 06:17 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Belts recommendations?
Have you checked the bearings and pulleys?
Old 03-29-2013, 08:05 PM
dannmarr's Avatar
I work for my SVX
How do I go about checking them? I already rebuilt the PS pump.
Subaru SVX for fun
Old 03-30-2013, 04:52 PM
kjoyes kjoyes is offline
Alt. & P.S.
Automotive V-Ribbed Belt (Standard) K050345
High Performance Automotive V-Ribbed Belt K050345RB (Blue)
A.C.
Automotive V-Ribbed Belt (Standard) K040335
High Performance Automotive V-Ribbed Belt K040335RB (Blue)
Old 03-30-2013, 06:49 PM
dannmarr's Avatar
I work for my SVX
Thanks for the info!
The Alternator/PS= 34"
The A/C=33"
The problem I'm having is the belts seem to long.
I'm at the end of the adjustment.
I know the belts stretch with time, but can I go a little shorter?
Subaru SVX for fun
Old 03-30-2013, 07:00 PM
Originally Posted by kjoyes View Post
Alt. & P.S.
A.C.
I have the blue gates alt/ps belt and it has held up quite well, and doesn't seem to have stretched noticeably in the last ~2 years. Plus, it's blue.
Old 03-31-2013, 06:08 PM
dannmarr's Avatar
I work for my SVX
To answer my own question, I used a stethoscope to listen to the bearings. No grinding. I then sprayed some belt dressing and the noise stoped. It's time for new belts.
Subaru SVX for fun
Old 04-05-2013, 12:03 AM
Green1995SVX's Avatar
I usually use Continental belts as they are very affordable and high quality. I have found, though, that the OEM subaru belts have a fuzzy coating on the inside. I'm not certain as to why it's there. Perhaps for more quiet operation? It's somewhat unique.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-05-2013, 07:06 PM
dannmarr's Avatar
I work for my SVX
I bought some Gator belts from Good Year. I am still having the same problem I had in the past, not the squealing issue but the size of the belts. They fit exactly to the extent of the tension pulley can go. They bottom out, so the belts can't be tightened further than I am accustomed to. Is this the way it is on our cars?
Subaru SVX for fun
Old 04-05-2013, 07:39 PM
Maybe it's the wrong size belt? Or maybe you can get one that's just a little bit smaller so it will fit and be tightened the right amount.
Old 04-05-2013, 10:23 PM
dannmarr's Avatar
I work for my SVX
Alt. & P.S.
A.C.
These are the numbers I used and they are the ones recommended on websites and part stores for our car. It's strange we have so much play on the adjusting pulley only to set it at it's max. Does anyone else have this issue?
Subaru SVX for fun
Old 04-06-2013, 12:28 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Contitech
1995 POLO LSI 76K MILES SOLD
