Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
View Poll Results: Stripes for my 94 Emerald Green SVX
No stripes 16 72.73%
Single black centered stripe 0 0%
Black centered stripe with very narrow black stripes each side 2 9.09%
Option 2 in yellow 0 0%
Option 3 in yellow 0 0%
Option 2 in gold 1 4.55%
Option 3 in gold 3 13.64%
Voters: 22. You may not vote on this poll
Old 11-30-2012, 05:39 AM
shotgunslade's Avatar
Re: Poll: Should I get a stripe and what color?
Final tally is in. Wife and daughter got 10 votes each. No stripe. Car is off to Dave Heinricks tomorrow. Will post post-respray pics.
Old 12-02-2012, 07:43 PM
Gold is a good color to go with the green.
Old 12-03-2012, 04:02 AM
Originally Posted by SilverSpear View Post
Haha true. I was flamed because of it.
I am currently working on a special project that involves it. I will definitely lower it though, probably by 2-3 inches.
If you lower it make sure that your lower control arms are level with the road!
And you were flamed more about the copper intake!
Keep your powder dry, my friend.
Old 12-03-2012, 04:17 AM
I redid it again. DEFINITELY one of the best Mods I've done.
OLD Box:
NEW box
If you have time OT, buy a Mustang 5.0L K&N Filter and fabricate the same copper box I did.
Old 12-03-2012, 07:29 AM
Danny,
You should see my airbox!
Old 12-03-2012, 08:17 AM
Danny,
Well... What are you waiting for?
