Old 07-27-2012, 11:13 PM
stiguy's Avatar
stiguy stiguy is offline
removing headgasket from block
Hey guys. So after blowing my engine i got another one from pick n pull. i decided to do the head gaskets before i put it in.
So there is gasket material left on the heads and block what is the best way to get them off. i was thinking dremel with non wire abrasive brush?
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 07-28-2012, 12:11 AM
Green1995SVX's Avatar
Re: removing headgasket from block
Gasket Scraper or a razor blade very lightly. Also a scouring sponge (like for doing dishes) can work well.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 07-28-2012, 12:33 PM
sunvalleyray sunvalleyray is offline
Great info on how to do it right - http://allwheeldriveauto.com/subaru-head-gasket-repair/
Ray
Old 07-28-2012, 04:07 PM
stiguy's Avatar
Kewl it says
220 dry
400 wet
600 wet
And to tilt the block downward for less debrie build up and a shop vac to get anything left.
Going to the store now to get that stuff
Old 07-29-2012, 09:28 PM
torxxx torxxx is offline
I use a Bristle Wheel to do all my Subaru blocks/heads. They make different colored ones (I was always told the yellow one on aluminum blocks/heads, green one for steel)
http://www.fastenal.com/web/products...9,r:3,s:0,i:85
They wont dig into the aluminum and wont leave scratches in the metal, but it will take off the old fiber/graphite gaskets that are a PITA to remove.
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 07-29-2012, 09:52 PM
stiguy's Avatar
ah kewl i will get one next time!
so the heads off the junk yard engine are pitted a bit and should be machined so i took off the heads from my blown engine and they look really good, they cleaned up like perfect! i'm going use them.
