Old 07-24-2012, 07:27 PM
kjoyes kjoyes is offline
Power mode switch Q:
Hi, i am putting in a power mode switch in my car it is a 1997
i bought a switch that lights up when it is in power mode
so i need to know what wire in car that will only send power to the light when it is in power mode.
like on the earlier models with the green light in the dash
do i need to tie into that to get it to light up on my switch?
the 96-97 dont have that green power mode light in the dash this would tell me that power mode was on.
Old 07-24-2012, 09:40 PM
Re: Power mode switch Q:
Any constant power should do it.
The light will only be on when the switch is in the on position completing the circuit.
This is of course assuming you have a switch like this with 3 posts.
Old 07-25-2012, 05:57 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Don't forget that the power mode switch is completing the ground circuit, so that diagram isn't exactly correct for this situation. It should have one positive supply wire (for the light in the switch) and one ground wire (from the car chassis), and then the other wire will go to the TCU harness to ground pin A4 (I think). Don't fry your TCU by supplying 12V to that pin!
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 07-25-2012, 07:01 PM
You right, I forgot we are just wiring a ground wire with a break in it, not a hot wire..
But yes, If that feeds 12v down the tcu line.. I think that would be very bad..
When I first looked at that switch, it looked to me like that 12v feeds the LED light only, because the same switch with no light is a 2pin setup.
So I thought that 3rd power post feeds only the LED, but at this point I wouldn't trust that without an internal wiring diagram of the switch.
I think I remember why I went with the switch without a light now. :P
On another note.. I have had power mode switch for 2 years now. I cant remember the last time I pushed it to turn off power mode.
The only time I don't want to be in power mode is when I am cruising at the same speed on the highway.
When I'm doing that I turn on the cruise control and that automatically turns off power mode.
Old 07-25-2012, 07:10 PM
SVX8588's Avatar
I'm not saying that diagram is wrong, just that it's a generic diagram
Some lighted switches have the terminals marked: power, ground, and accessory. If that's the case, you'd have to wire it backwards to get it to work right since the switch connects the power and accessory terminals. So basically you would want to connect chassis ground to the power terminal on the switch, connect the accessory terminal to the TCU, and connect your positive power source to the ground terminal on the switch. Keep in mind that this won't work if the light in the switch is an LED, because LEDs are polarity sensitive.
My power mode switch is lighted, but it's also not a regular lighted switch.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 09-06-2012, 09:55 PM
JesseSVX's Avatar
JesseSVX JesseSVX is offline
So what kind of lighted switch did you use?
One like this right?
Old 09-08-2012, 10:27 PM
I USED A SWITCH OUT OF A 1995 NISSAN PATHFINDER ALOT OF THE SVX SWITCHES ARE FROM NISSAN IT IS A SWITCH FOR POWER MODE SPECIFICLY.
I have it all wired in it has a green ilumination blub for at night and when i am in power mode it has a amber light telling me it is on.
(i had to take the swich apart to put the green condom on the bulb so it would match the interior
i bought mine off of ebay here it is http://www.ebay.com/itm/1995-Nissan-...a90461&vxp=mtr
i mounted it where other door lock switch on the wood trim around the shifter
i used a soldering iron to make another hole for the extra swich.
Old 09-09-2012, 06:01 AM
Wow that has got to best switch for Power Mode I have ever seen.
Old 09-09-2012, 06:55 AM
just to throw in a little extra info the early 90's nissan pintara
also has that same switch
Old 09-09-2012, 10:08 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
I used a forester AC switch to fit in the JDM location
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 09-09-2012, 10:10 AM
pearlm30's Avatar
Old 09-09-2012, 10:16 AM
pearlm30's Avatar
Old 02-16-2013, 12:46 PM
Here is the switch I used it is a power mode switch out of a Nissan pathfinder 95 or something it is the exact same as the door lock switch that is made by Nissan. I have it so when when power mode is on the light comes on and it was a amber light so I put a green condom on the bulb so it will match the interior illumination.
Old 02-16-2013, 01:31 PM
dragoontwo dragoontwo is offline
404: picture not found.
'92 SVX LS Pearl White - 6mt
Old 02-16-2013, 03:04 PM
