Old 05-27-2012, 06:43 PM
kjoyes kjoyes is offline
How to change the front blinker lights?
hi like the title says want to change my front blinker?
Old 05-27-2012, 06:47 PM
Onor's Avatar
Onor Onor is offline
Re: How to change the front blinker lights?
If you are talking about the front markers (turn signal), there is a screw above the top of the headlight that you can unscrew, then pull the marker light straight forward to get it out. You'll have to unplug the light as well before you pull the marker light out!
~TEck
Old 05-27-2012, 07:02 PM
ok thanks,
i try it now!
Old 05-28-2012, 01:05 AM
You will also see a guide pin on the lower part of the turn signal housing which aligns and slides in and out of a hole in the fender. This is what holds the turn signal securely at the bottom.
The screw in question goes through a hole in a bracket attached to the turn signal. you can see it to the right side of the photo, outside of the headlight protector
Old 05-28-2012, 09:21 AM
ok thanks,
i'll try it now!
