Re: Do replacement wheel bearings need to be re-packed or not?
The grease does go bad after time ( shelf life ) I would repack the bearings with the grease I know is good, just for my own peace of mind.
And that is coming from an ex Timken employee. |
And it wasn't some yahoo from an internet parts store I talked to. It was a representative from Timken! [/QUOTE]
I would not spend too much time trying to figer it out, Tony. The best way has been pretty much common knowledge for years! Good luck. Keith |
Seems like nothing is simple. I went to auto parts stores today to buy a bearing packer, Mobil 1 grease and cleaner. They had chlorinated and "green" nonchlorinated brake cleaners. Are both safe or just one or the other for the plastic in the bearings?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Brake cleaners evaporate very fast. They probably won't stick around long enough to do any damage even if one of them was able to solvate the plastic a bit. If you're a little worried, get the non-chlorinated one.
I guess I will stick with it. Any suggestions on how to not make an absolute mess when cleaning out the bearings with this stuff? I was thinking of putting it in a funnel and letting the goo drip into my "old oil" container I use to re-cycle used oil from my mowers and stuff.
But worse for the environment...
Really better for your health? That's surprising. Whatever they put in the non-chlorinated stuff must be really bad then. In the chem lab, I love my chlorinated solvents. I just used a bunch of paper towels and kept wiping it off. Your main concern really needs to be keeping any dirt/sand/dust far, far away from the exposed bearing. Wear some fresh nitrile gloves (latex probably won't stand up well to the brake cleaner).
OK, I am going to give this cleaning and repacking thing a shot today.
In the mean time, I have a question about torquing down the axel nut. Is there a special procedure similar to the one Timken suggests: http://www.timken.com/en-us/solution...nt_English.pdf Or, do we just torque it down to specs according to the service manual? And, speaking of that, I have pdfs of both the 1992 and 1997 manual and they are not quite the same. See the attachments. First, the torque specs are slightly different. Second, there appears to be an additional oil seal in the 1997 manual that sits behind the inner seal for the bearing. It is item 12 on Figure 2 of the 1997 pdf. No one has ever suggested changing this particular seal but maybe that is because most of you have older vintage cars. I have no idea at what year they would have added this seal. Any idea when this seal was added and whether or not it should be replaced? Does the axel nut need to be replaced or not? Very few people suggested it but at least one person did. I didn't order it and I am not sure if the local dealer has one in stock. Finally, which lateral link bolt is undone during this job, the inner or outer?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 05-17-2012 at 07:58 AM. |
I thought those were the pages from the Subaru manual. Is that incorrect? If so, does anyone have the correct torque values?
The manual says 123-152 ft. lbs. for the axle nuts.
Usually the torque range is for new or used fasteners (with the lower number forca new, unstressed nut) Very similar to the torque values for the lug nuts. The FSM has a range of between 72-87 ft. lbs. The first number usually is for new, unstressed fasteners and the higher number for used. Most members split the difference and run about 80 ft.lbs on the wheels . .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 05-17-2012 at 07:53 PM. |
Thanks John. I cleaned and re-packed the bearings today. First of all, the grease that was in there didn't seem as bad as people made it out to be. Second, what a royal PITA!!! Cleaning the old grease out was nasty. And when I looked at the bearing packer from Lisle and the bearings, I couldn't see any way that would work. So I hand packed them. Again, what a PITA!!! I think I got nearly every trace of the old grease out and I hope I put enough grease in them when I replacked them. I pushed it in the bottom until I started seeing the grease ooze out of the other side. I then put a thin layer of grease on the outside of the bearings and the rest of the inner race.
Thread Tools | |
Display Modes | |
