Old 04-24-2012, 03:49 PM
Re: Wanna go 5 speed Where r the parts?
Wyatt does the $25.00 have todo with anything?????
Dumb fingers .Dumber spell check.What does $25 have to do with anything. I looked, it's a used clutch is only worth $25
iPads have a mind of their own. Gave you some reason to comment .
The clutch is the weak link in the chain .
Old 04-24-2012, 03:55 PM
Green1995SVX's Avatar
Who are Wyatt and Todo?
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-24-2012, 04:27 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Lol I was wondering the same thing but you stated it much funnier than I could.
Old 04-24-2012, 05:17 PM
Hmmm, used legacy clutch parts... Sure hope you've got an extra $300 for a decent clutch when that one fails instantly once driving.
That pressure plate was designed to hold for an engine with 170ish hp tops, and that's if it's from a legacy GT, Outback, Forester, etc with a 2.5 and would be a hydro setup. If it's a cable, then it was meant for a car with about 135hp. Just not going to cut it behind the 230hp and 228lb/ft of torque in an EG33.
Oh well, have fun with a slipping clutch.
Old 04-24-2012, 05:48 PM
Ankh599
You have a PM
mistake on PM ,The seller is in PA not GA
Old 04-24-2012, 07:37 PM
I run a cable setup with a stock excedy clutch, and it does fine...might not be a good setup for racing, but is fine for a driver, don't let the negative comments bug you.
Old 04-28-2012, 03:04 PM
Ankh599's Avatar
Ankh599 Ankh599 is offline
Originally Posted by huck369 View Post
You need to bring it to the Dragon Meet in June (and your mechanic too )
Definitely. Most of my upgrades (Hoping fresh paint) will be done by then.
Old 04-28-2012, 03:05 PM
Ankh599's Avatar
Originally Posted by Crazy_pilot View Post
Link.
Brand new Spec Stage 5 racing clutch for a 98 Legacy for $485. A good used STi 6MT clutch is ~$200. A 14+ year old Legacy clutch, with ancient bearings, is worth almost nothing.
Gotcha...Thanks.
