Old 04-06-2012, 12:07 PM
Onor's Avatar
Onor Onor is offline
Removing/Inserting the Flange Bolt From the Trailing Link
Hey All,
A friend and I have been taking apart my 1992's Suspension in order to replace all the bushings with the poly bushings in the Polish Bushing Kit. The suspension came apart suprisingly easily other than one set of bolts:
Flange bolt that connects the Trailing Link to the Rear Subframe.
We were able to break the bushings free of the trailing link and pull it over the bolt, so they are out, but the flange bolt, washer and bushing were still there. We still weren't able to get the bolts to break, so with a lack of other Ideas, we cut the flange bolt on one side to get it out.
When we checked to put a new bolt back in though. We found that we couldn't get the bolt through the trailing arm, as it hits the inside of the wheel well.
So, how do we get those bolts in and out? Do we need to cut a hole in the wheel well to get the bolts out? Or is there some other trick to get them out that I don't know about?
Thanks!
~TEck
Old 04-06-2012, 12:18 PM
Old Fogey
Re: Removing/Inserting the Flange Bolt From the Trailing Link
Will the new bolt slide in from the opposite side?
Glenn
Old 04-06-2012, 12:20 PM
Old Fogey
I'm looking at the factory manual and there's no specific mention of any "trick" to R&R of that bolt, but I recall having the same issue dismantling my wreck.
Glenn
Old 04-06-2012, 12:29 PM
Onor's Avatar
Sadly, no. The bolt won't come in the opposite way either. The gas tank is in the way.
~TEck
Old 04-10-2012, 08:52 AM
Onor's Avatar
So you all know, we were able to get the bolts out of the car. Not very gracefully though.
We banged a dent in the front of the wheel well (behind the plastic protection), which gave us the clearance to remove and insert the trailing link bolts.
We then sanded/cleaned the dents and painted the area to help with rust prevention.
Thanks for the help!
~TEck
