Old 04-02-2012, 06:37 PM
moepower moepower is offline
head gasket job
what's the best way to do them pull the motor
Old 04-02-2012, 09:18 PM
Re: head gasket job
Yes.234567
Old 04-03-2012, 07:16 PM
davew833 davew833 is offline
Re: head gasket job
I won't say it's the best way, but I did mine on my first SVX by jacking up the engine until the heads cleared the frame rails. It wasn't too bad really. I didn't have access to an engine hoist at the time and didn't realize how really easy it is to pull an EG- or EJ- series engine.
davew833@yahoo.com
Former 6-time SVX owner
Old 04-04-2012, 12:21 AM
Re: head gasket job
Depends on how much more engine work you plan doing at the same time
Replacing valve cover gaskets, spark plugs, timing belt and idlers and a water pump are infinitely easier when on an engine stand out of the car.
Well worth the upfront work to make it all flow smoothly later. A spark plug change can be done in as little as 9 minutes!
Old 04-04-2012, 06:29 AM
Re: head gasket job
Well worth the upfront work to make it all flow smoothly later. A spark plug change can be done in as little as 9 minutes!/
What, are you high?
Old 04-04-2012, 10:52 AM
kwren's Avatar
kwren kwren is offline
Re: head gasket job
What, are you high?
High? Sounds a little low to me... might take as long as 15 minutes!
Keith
Old 04-04-2012, 11:30 AM
Re: head gasket job
Keith
Yet again an inside joke.
TEEHEEHEEHEE, snort!
http://www.subaru-svx.net/photos/user.php?boxer6|19095
