Old 03-06-2012, 12:22 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Pass. side hoses to radiator (transmission or not)?
As the title suggests, is this one of the the hoses from the transmission into the radiator to cool it? For the life of me I've spent 40 minutes trying to find a diagram that shows it but I fail. Apparently I also have all the PDF service manual sections except the transmission? Nice.
From what I can see on Subaruparts it appears to actually be the driver side. However, if that is the case... what hose is this too? If it IS the transmission cooling line, that would quite possibly explain the billion air bubbles in the ATF. If it's not then wth is it? (is the power steering cooled somehow through the rad too?)
1994 subaru svx le 112k
Old 03-06-2012, 12:26 PM
dragoontwo dragoontwo is offline
Re: Pass. side hoses to radiator (transmission or not)?
If the line actually connects to the radiator, it should be for the transmission. The power steering hoses go to a loop for cooling just in front of the radiator.
The transmission hoses run on the drivers side, while the power steering hoses run on the passenger side.
'92 SVX LS Pearl White - 6mt
Old 03-06-2012, 12:35 PM
Yep!
What Mike said.
Old 03-06-2012, 01:07 PM
cthommes cthommes is offline
More importantly is that fluid oil or ATF? Hard to tell in the pic. However, the picture seems to point more to oil leaking from the timing case area (cam seals) and/or valve covers... dripping down onto that power steering cooler loop hose you're inquiring about.
Mine looked the same way, and mine was definitely valve covers and cam seals (since repaired).
Old 03-06-2012, 02:26 PM
Both systems, power steering and automatic transmissions use Dexron ATF. (Automatic Transmission Fluid)
Old 03-06-2012, 02:37 PM
Correct, but the cam seals and valve covers do not leak ATF. That was what I was trying to get at-- the pic to me looks more like the leak is an engine oil from the timing case and/or valve cover dripping down onto the PS line (which should, as you indicate, carry ATF).
Old 03-06-2012, 02:50 PM
Subix's Avatar
Thanks guys. Yeah there's an oil leak up here but the line leak is for sure red atf. The driver side lines are perfectly dry and normal looking. Hmm
Old 03-06-2012, 05:54 PM
You are of course correct, Sir, in that oils run downhill.
Gravety works.
However I would say that most SVXi have/are using hoses, gaskets, and seals that are getting old, hard and dry.
It is hard to say without actually being there.
Old 03-06-2012, 06:01 PM
Gravety works.
Indeed. OP has since confirmed it's red, so I think we can safely assume all of the above (pun intended) are leaking.
