Old 02-14-2012, 02:50 PM
92 SVX 92 SVX is offline
Re: Remote Mount Turbo
I believe steel was being facetious, and taking your statement of "on the turbo" literally.
Oh and curious his comment actually reminded me. Are you going to wrap the exhaust all the way back to the turbo? and or use a turbo blanket? I am not sure if hotter exhaust through the turbo would be helpful or not.
Old 02-14-2012, 03:02 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Hey, I read "right on the turbo". You never know
One think I want to ask though is I believe you mentioned catch cans? I picked up two recently myself (for the crankcase and PCV) and I'm sure you know they need to be under vacuum to work correctly... Which as far as I can tell in our application would mean running two lines to the back of the car where our air intake pipe will now be located. Is this what you were planning to do or is there something smarter I just haven't thought of yet?
Old 02-14-2012, 09:39 PM
Subaru Alliance Subaru Alliance is offline
well the bad news is I didn't get any parts in today. The good news is pics.
Here is the turbo, it's a GT35, I used the book as a reference to the size of it, it's close a high school/college text book in length, height, and width. That's why I decided to chop out the pare tire well.
The electric pumps from left to right, 132GPH, 100GPH, and 1GPM
This is the heater core which will be my radiator, the "intake" and exhaust flanges for the exhaust side of the turbo, and a piece of misc intake piping plumbed for the blow off valve
2003 Baja Sport
1994 SVX LS
1992 SVX LSi parted out
Old 02-14-2012, 09:53 PM
@STeeL25T The purpose of my catch cans are really just to be reservoirs, for the oil and coolant. As far as vacuum goes, I really haven't decided yet, I was thinking of something along the lines of a "power strip" one central location to draw power from, but in this case maybe a "vacuum strip" I am considering routing the vacuum lines to a central area and using a check valve with the source of the vacuum being the intake "when not under boost" But I have also considered using a vacuum pump. I have considered the vacuum strip, drawing vacuum from the intake as well as a second source being ran to the intake side of the turbo. to be completely honest I am still open to suggestions and that may be a trial and error set up for me.
2003 Baja Sport
1994 SVX LS
Old 02-14-2012, 09:56 PM
Niiiiiiice
Needa get me one of those. Or possibly, two, smaller ones of those
Old 02-15-2012, 04:20 PM
I got my electric fans in today. It will fit perfectly up against the heater core. Here is a pic of the fan, and then one of the fan against the heater core.
It fits like a glove
2003 Baja Sport
1994 SVX LS
Old 02-15-2012, 04:42 PM
Talking to my buddy here and he gave me a great idea for the PCV set up. I may just go with a small filter on one cam cover, and then the other cam cover through a check valve into the intake manifold, so when not under boost then one cam cover will draw vacuum and then the other will let fresh air pass through the engine I may have to think of a way to add some sort of restriction there so it's not a HUGE vacuum leak.
2003 Baja Sport
1994 SVX LS
Old 02-17-2012, 09:23 AM
Ok so for another update, yesterday after work I came home to find that my coolant reservoir, blow off valve, and o2 sensors came in today. I am gonna hit up the hardware store for some brass fittings, and I should be getting some more parts in today so I will update with more pics this evening.
2003 Baja Sport
1994 SVX LS
Old 02-17-2012, 10:22 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
intresting aproach and project you have your work cut out,
i been inolved with turbo AWD cars for 15 years now starting with dsm's and making a monster evo x
working with a n/a and converting it to a turbo car has lots down sides thats not to your favor,
best of luck and keep us updated =>
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 02-18-2012, 08:47 PM
Jay Wrix Jay Wrix is offline
very beautiful, was thinking about a similar project,
they do make vacuum powered pumps for stuff like that, belt driven off the motor (morrosso) specifically for boosted applications, if you do need that...
what are the ports on the turbo for?
DOHC boxer six, second best sound to the ears to the Ford inline 300!
Old 02-19-2012, 07:50 AM
They do make them 96-99 and possibly other years chevy turbo diesels have belt driven vac pumps, of course on them it doesnt make any sense the only thing requiring vac is the waste gate they could have just made electric or even mech waste gate controller.
Old 02-19-2012, 09:00 AM
brake boosters require vacuum to operate as well as cruise control
(correct me if diesel trucks are differnt, i know airbrakes are....)
Old 02-19-2012, 01:11 PM
@ Jay Wrix' comment that is right. the reason vacuum pumps are used on a diesel is because there is no throttle body on a diesel, like there is on a gasoline engine. The throttle body being closed off while the engine is running is what creates the vacuum, a diesel however is allowed to get a full charge of air at all operating speeds, and the engine speed is controlled by fuel alone, a gas engine you have to control air and fuel flow to prevent leaning out.
The ports on the turbo, I assume your talking about the long metal tubes that come off if it, these are for coolant, one supply, and one return. the small fitting in the middle is for oil supply, and there is one on the bottom you can't see in the pics is the oil return. some turbos are oil and air cooled, this one is liquid cooled, the oil and air will draw some heat off, but mostly liquid cooled.
Quick update on the build, I am fabbing up my exhaust flange, and hope to get the turbo mounted today, if not by tomorrow definitely and I will post a few pics. I got my trans cooler and electric fan mounted, and everything is plumbed for the oil system, I will test it for flow after everything is mounted and if satisfactory I will run it like for the time being. I won't plumb anything from the turbo to the intake yet, I am waiting on my stage 2 ecutune, and then an engine swap, then the last of the intake plumbing.
2003 Baja Sport
1994 SVX LS
Old 02-19-2012, 01:14 PM
no, i knew that i was refering to all the apparent holes around the inside of the turbo where the air goes in,
Old 02-19-2012, 01:22 PM
O my bad, those are for some sort of anti surge. I bought two GT35's they both arrived at the same time, one has those anti-surge holes, and the other does not, other than that they are identical. I have never seen these anti-suge holes on any other turbo before. I guess we'll see if they "work" LOL
I just used and searched for anti surge, there is a lot of info on it.
2003 Baja Sport
1994 SVX LS
