Old 02-10-2012, 02:48 PM
92 SVX 92 SVX is offline
Squeaking from RF
ok this vid hopefully you can hear the squeaking I have only heard this with bad brakes or something dragging on the rotor but I carefully checked the dust shield and it was not contacting the rotor.
Old 02-10-2012, 09:33 PM
Tapani Tapani is offline
Re: Squeaking from RF
Is there a wear indicator on the pads? Kind of a metal spring which will touch the rotor when the pads are worn enough.... it's purpose is to make a sound like that .
Kind regards,
Tapani
Old 02-10-2012, 10:05 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Could be a rust ridge on the back side of the rotor- I just removed one from my Impreza wagon this week that was causing an awful squeal.
Old 02-11-2012, 08:23 AM
Its a good thought on the brake pad wear indicator, however the pads are less then a year old, and so are the rotors, I took the car to the body shop on tue picked it up friday and that sound was going on.
