Old 10-01-2012, 04:34 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Re: EGR valve
Just a quick update, I did take the SVX by and had it inspected. Whoever told me that the CE light didn't matter was correct. The tech said that since it was OBDI that he'd have to test the emissions directly so the CE light didn't matter. He hooked up the machine, and the emissions were fine so I got my sticker.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 10-01-2012, 07:50 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: EGR valve
Lookin4svx, when you stick those hoses in the seafoam can are you supposed to then start the engine and have it sucked thru
1995 POLO LSI 76K MILES SOLD
Old 10-01-2012, 12:35 PM
Re: EGR valve
I have no idea, I have never seafoamed anything.
I just found that random pic on my HDD in a folder called "seafoam" inside my svx folder.
Just that 1 pic was in the folder, no instructions.
I guess I assumed the instructions would be on the can.
Old 10-01-2012, 03:09 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: EGR valve
There's videos of people doing it all over youtube, but every engine is built different, therefore every engine must be seafoam'd differently. Anyone here done it? I can always just put some in my gas tank, but if there's a way it'll get to that EGR quicker/better I'd be all over it.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 10-01-2012, 03:27 PM
Re: EGR valve
Ok. So you're throwing a code for the EGR solenoid and you want to clean it out? Just follow the lines in the vac diagram on the previous page and you'll see what to do. As long as the fluid moves through the EGR solenoid (# 11 in the diagram) it ought to get cleaned out.
Old 10-01-2012, 05:10 PM
92 SVX 92 SVX is offline
Re: EGR valve
After picking the vac tube you want to use the easiest method to doing this will be to use up (pour into the fuel tank or another container) all the fluid in the can except what you want to go through the vac system, I think the can says to run about 1/3 of the can through the vac lines.
Then at that point you will start your engine let it idle while it is idling you will pull the vac line you chose and stick the end of it into the seafoam can but be warned it will almost instantly flood out the engine if you just hold the line in the liquid of the can your best bet for sucking all the liquid up is to bob it up and down into the liquid till the liquid is gone or when almost completely gone submerge the line so that you suck up the remaining liquid and at the same time it floods the engine so it kills it, then you wait the recommended ( i think 5 mins) then restart the car, that gives the seafoam a chance to sit in the vac and intake passages dissolving any build ups.
