Old 08-16-2011, 11:51 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
our car is on here?!
http://tbcwheels.ridestyler.com/?mode=webtk
just thought it was kind of interesting to see our car with any kind of rims we want
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 08-17-2011, 12:10 AM
fun173's Avatar
fun173 fun173 is offline
#1 BRODAWG!
Re: our car is on here?!
That Is awesome. i could play with it for hours. I want this!!!!!!
I think our cars look nice and menacing tinted, and lowered.
File Type: png Screen shot 2011-08-17 at 2.09.11 AM.png (181.3 KB, 128 views)
Old 08-17-2011, 01:28 AM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Fun to play with but I'm so picky I couldn't find a pair of rims I would want to buy and put on...
1994 subaru svx le 112k
Old 08-17-2011, 10:49 AM
zaueugen's Avatar
zaueugen zaueugen is offline
how would 36mm offset work? would it effect the handling?
Old 08-17-2011, 12:22 PM
XT6Wagon XT6Wagon is offline
offset is how much the rim centerline is offset from the hub face. Stock is +52mm IIRC. This site is clearly pedaling Nissan/Mitsu fitments that are not going to fit and drive any where near as nice as using the OEM offset.
If you want to get the right rims, I use a search for 2005 STi rims as it uses the same bolt pattern and offset. Also the sites like tirerack or wheeldude seem to limit it to widths/offsets that will fit in our fenderwells. Dunno if the same would be true if you searched for 2008+ STi aftermarket rims.
Oh and NEVER listen to stancenation people on wheel or tirefitment. FOR ANYTHING. Rarely listen to autoX STi owners, they can get a little insane pushing the very last mm of tirewidth which might not work for your SVX.
Old 08-17-2011, 12:28 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I tried Nissan 350Z wheels with a 38mm offset and they rubbed the fender edge (235 x 17 tires). I now have wheels with a 45mm offset and no problems.
Gene
Gene and Ben
Old 08-17-2011, 12:36 PM
Huskymaniac's Avatar
Uses the ignore feature
I thought stock offset was +55mm?
My favorite was the DIP Laser D95. This car is of Italian design on the outside and Italian body styles scream for star shaped 5 spoke wheels.
Tony
Old 08-17-2011, 12:39 PM
zaueugen's Avatar
yeah i love these 5 spoked wheels but i guess the offset 36 will not work well with the svx, any other similar rims with a more natural offset for the svx?
Old 08-17-2011, 01:40 PM
It might be, Subaru seems to use a range offsets across the different cars and I sometimes have trouble keeping them straight.
http://www.wheeldude.com/catalog/ind...Path=90_217_91
These will work on your car with correct offset and hub bore. Try NC miata (2006+) or RX8 for a few more options that are close in offset, but don't have correct hub bore.
Sometime I want to try 2002+ explorer rims for fitment. Not too expensive used and most should be in good shape with the fat squishy tires protecting them from curbs and potholes.
Old 08-17-2011, 06:18 PM
michael's Avatar
michael michael is offline
What Potholes ???
Where was this like 10 years ago
Wanted: Steering Wheel
