Old 05-05-2011, 02:21 PM
Re: Hydraulic Lifts.. ???
Once you drill out the back of the rivet that holds the stock hood bracket to the shaft, the parts will separate and you will find the white nylon bushing.
This bushing allows the parts to keep the shaft of the ball stud centered in the hole. There isn't a lot of stress on the nut; I just applied some Loc-Tite to the threads and tightened the nut snugly, that's all you need to do.
Use 2 ball studs for each side. One is attached into the hood, where the original ball stud is attached to the strut and one on the bottom bracket.
You can use one of those nylon center/ metal locking nuts if you prefer.
Old 05-05-2011, 02:29 PM
Originally Posted by James Scott View Post
OK!.. Do the nylon washers come with the SPD struts for the hood? NO
Do I need to find them somewhere?? NO
Are they part of the stock system and retained for this use? YES
Does the hood ball stud just go in an existing threaded mount on the hood? YES
I see list has (4) ball studs to order YES, 2 for each side
Old 05-05-2011, 04:31 PM
The Molinator
ThAnKs! .. .
Jim
Old 05-08-2011, 07:05 PM
The Molinator
Installed trunk lifts today.. NICE! Waiting for hood lifts.. soon I'm sure.
Thanks, Jim
Jim
Old 05-09-2011, 10:18 AM
The Molinator
Heh! My trunk stops anywhere in the middle!.. even without crashing down! ... or cutting off fingers..or hands!
I don't even remember (old) when the trunk did THAT!.. . Ha!
CoOl!
Jim
Old 05-14-2011, 02:41 PM
The Molinator
Installed the HOOD lifts last nite.. They're great! Hold the hood up so high, I cud pull my engine out with the hood ON!
Thanks, guys .. Jim
Jim
