Old 01-31-2013, 03:16 PM
bishop bishop is offline
Re: rear sway bar project
I can understand that we want to improve handling but wouldnt a larger front bar cause more understeer?
Old 02-17-2013, 07:51 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
done and ready to ship !!
We are building Qtys of 10 at a time
$185 each plus shippping.
Solid bars, come with urethane bushings and new brackets.
Ours are made by a major sway bar manufacturer done
to our specs and with their input too.
www.planetsvx.com
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 02-17-2013, 10:51 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
Is this the rear bar or front...either way I'll take one but don't see it on your site
[SIGPIC][/SIGPIC]
Old 02-18-2013, 01:43 AM
Rear...
the fronts feasible, but the cost willl be much more
if we decide to do it.
It will be up on the site by tomorrow (the new rear)
or you can call me with your order or I can send you a payapl inv.
email me directly
motorsport_svx@yahoo.com
thanks
Dayle
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 02-19-2013, 03:17 PM
kjoyes kjoyes is offline
.75 or .875 (22mm) if we wanted
what size bar are you selling now?
Old 02-20-2013, 04:50 PM
shotgunslade's Avatar
Stiffer front swaybar will decrease understeer. We really need a stiffer front swaybar solution that will also address the issue of the connection to the front control arm. I believe SVXRide had a problem with his control arms due to larger bar.
Would be willing to pay reasonably big bucks for a good front sway bar upgrade.
Old 02-20-2013, 05:02 PM
theflystyle's Avatar
so whats being used for the endlinks?
1994 SVX LSi
2008 Legacy 3.0R
Old 02-20-2013, 06:20 PM
Originally Posted by theflystyle View Post
so what's being used for the endlinks?
In the very first post of this thread Dayle says the factory links would be used. Seems like they need to be beefier. That's why OT came up with the "$20/ 20 minute mod".
Old 03-06-2013, 01:17 AM
Got a few bugs to work out with the hardware on the rear bar
Installed mine today. Figured out what hardware will be needed
at any hardware store too.
Got the bar mounted to the endlinks I used some nylon washers
but think the manufacturer is going to make me something and include
it in the bar. Its an easy fix, and some people may want to use
different methods for this depending on how solid they want it to be.
I noticed it immediately the first time I made a hard turn on the way
home. Felt good, just takes some getting use to.
As long as rest of your suspension is in good shape and you are running
better then avg softer tires, youll get the most out of the new bar.
My car has our drop springs in it, stock struts, and 225-40-18 Continental tires on it for comparison.
Ill post more pics tomorrow nite.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 03-23-2013, 03:54 PM
Nevin's Avatar
Nevin Nevin is offline
Best of luck, Dayle!
I got some HID's from you a few years back and they still work amazingly.
Frankly, it doesn't bother me at all if someone else makes a rear bar. I've sold about 35 now, and like I've said many times, the only reason I got into it was because I wanted a larger one for myself and nothing existed. I am not trying to hijack dayle's thread by any means, but I've got 5 bars left in my posession, and when they're gone I really doubt I'll make any more. Making the rear bar was actually a piece of cake, honestly. I'm surprised someone else hasn't made their own by now. The only thing that's custom is the bar itself, and any competent machine shop can bend you a bar of steel of any length and hardness to whatever shape you desire, (including patterning it it after the stocker) which is why I'm surprised more hadn't done this before.
A front bar is going to be MUCH harder, because like Bill eluded to, the problem is two-fold. First, it has to be a two piece bar (splined at one end like the stocker) which would drive up costs, and two, you'd have to have a good place to connect the thing to the struts. Custom work would have to be done on each, and for the amount of work and cost it would take, it's not worth the investment for anyone to take on a project where they will sell MAYBE 10 of something.
Mine have always sold for $260 shipped anywhere in the lower 48 (except for special colors,) so if you can do it for any less, by all means be my guest.
Dayle has been serving the svx community for longer than I even knew it existed, so if he has something to offer for a better price than even I can do, I'm all for it.
This is a great group of people I have met here, and I'm proud to own one of the weirdest cars on the road like the rest of you here!
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 04-22-2013, 09:38 PM
jman050's Avatar
Its a Classic!
any updates on when the rear bars will be shipping?
[SIGPIC][/SIGPIC]
Old 05-01-2013, 08:38 PM
jman050's Avatar
Its a Classic!
Did anyone else order one of these?
[SIGPIC][/SIGPIC]
Old 05-02-2013, 04:59 AM
I have one on order....
Old 05-02-2013, 11:56 PM
let us know when you get it and how you like it.
Old 05-03-2013, 05:06 AM
Will do....
