Old 03-27-2011, 05:22 PM
K_Dub's Avatar
K_Dub K_Dub is offline
Headin' for the hills
Re: auto seat belt stuck
A while back someone found out what the intermitent seat belt fix was. I don't remember who it was, but maybe someone else does. It would be good to find it and I will get it into the How-To Docs.
That might be me. I've given the wiring diagram out to a couple of members, but I'm not sure anyone else has tried it yet. Over 2 1/2 years with a brick of relays back there and my seatbelt has never let me down yet. When I get home I'll pull the PDF and send it to you, if you'd like.
Edit: I've attached the Wiring Diagram. It's pretty self-explanatory but if you have any questions just hit me up. I haven't looked at this stuff since I installed it, so I might need to jog my memory.
In a nutshell, with a multimeter we found that one of the two wires leading to the motor was dead. That means that when that wire is Negative (-) the belt still functions, but when it needs to switch to Positive (+) it isn't sending power to the motor (i.e. belt goes forward, but doesn't return). The Yellow, and Green wires (Door Trigger, Belt [forward] Trigger respectively) were found locally in the space behind the door. Grey and Red (Ignition Trigger and Constant +) were brought from under the dash. A fuse was placed in-line on the Constant +, and we tested it until we found the right rating (basically we stopped the belt motion by force and the fuse blew, we kept blowing fuses until we found a rating that seemed good).
Hope this helps somebody. I'd be honored to contribute this to the network. If you think it'd help I could tear back into it and take some pics.
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner
Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor
Buying parts is like car payments. Someday she'll be all mine.
Old 03-27-2011, 06:54 PM
Originally Posted by 92_LSL View Post
Yeah my dome light works perfectly fine. The thing I don't get is when I crank the belt back manually then shut and open the door the belt goes forward but doesn't go back.
Unplug the motor, so it won't go forward again. Then crank it back.
Old 03-27-2011, 07:33 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
Will do. Hey do you still have that motor ?
I has teh FWD LS-L
Old 03-27-2011, 07:37 PM
It's going to be rebuilt 11:1 CR over the summer, if at all possible.
Old 03-27-2011, 07:44 PM
92_LSL's Avatar
Do you know anyone with an engine for sale? I recently discovered I have blown ring lands on one of my pistons and i has scarred the cylinder walls past the point of repare. I have had a crappy year and I have had ongoing financial problems and this caused me to not be able to buy that engine.
I has teh FWD LS-L
