Old 03-07-2011, 05:45 AM
dcarrb dcarrb is offline
Check Engine Light: A basic question
Shouldn't a check engine light stay illuminated until the offending code is cleared? What would cause the light to come on, then abruptly go out just a couple of miles down the road?
Okay, so that's actually two questions...
dcb
Old 03-07-2011, 07:27 AM
Stillhoff Stillhoff is offline
Re: Check Engine Light: A basic question
Yes, if you have a foult.
A guess: the lambda.
http://www.subaru-svx.net/forum/showthread.php?t=54033
Old 03-07-2011, 02:28 PM
I have a CEL that comes on sometimes when I start up the car then goes off a little ways downt he road. When I pulled the code it was EGR issues.
Old 03-07-2011, 02:44 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Here's the simplified version:
Each sensor is tested several times a second.
One bad result is usually ignored, but if you get several bad results in succession the ECU will decide there is a problem and trigger the light.
If you then get a whole load of good results without any bad ones then the ECU will decide the problem has gone away and turn the light off again.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-08-2011, 05:54 AM
Thank you. I figured maybe it was the budget, no-name, 87 octane, petro-byproduct-laced "gasoline" with which I topped the tank before commencing a 2-hour highway run Sunday night that had my engine scratching its head. Haven't seen the CEL again.
dcb
Old 03-08-2011, 09:50 AM
gbianchi gbianchi is offline
I also have had this cel situation, I believe it caused by old hard vacuum lines, always goes off though..........G.
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
