Old 10-26-2011, 01:51 PM
The Molinator
Cool Re: Fuel gauge woes
I have a wacky gas gauge now .. showing 1/4 tank at FULL! AND, also about 4 gallons from empty.. starts to die.. when stopping.. or turning left.. ???
The wacky reading just started last night.. The running out of gas early started after I replaced a faulty fuel pump with an aftermarket.. adapted to OEM mount.. .
Thanks, Jim
Jim
