Old 02-18-2011, 07:44 PM
3.3H6's Avatar
3.3H6 3.3H6 is offline
Limecat is not amused.
engine noise w/ video
http://www.youtube.com/watch?v=gI9wUQHX3gg
posted a video of the engine running, any ideas? i'm afraid to drive it to the dealer 30 miles away
1992 Subaru SVX: sold after months of problems.
1995 Volvo 850 T5R sedan
2011 Subaru Outback 3.6R limited: excellent all-rounder
Old 02-18-2011, 09:41 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Re: engine noise w/ video
It sounds a lot like two words: "bearing" and "spun"- put them in the order you like, but it sucks either way.
Old 02-18-2011, 09:48 PM
3.3H6's Avatar
****,****,****, etc.
This won't be cheap if it is. oh this is gonna screw my miserable bank account over.
Old 02-18-2011, 10:36 PM
Cam Cam is offline
You can take the oil pan, sump and windage baffle off. This will allow inspection or the rod bearings. You may also check for evidence of a spun main bearing (look very closely at #5). It would most likely be worth it to just get a donor engine.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 02-18-2011, 10:51 PM
3.3H6's Avatar
yeah, that would be great, if I weren't a poor, jobless college student with little time in the week to be doing an engine swap. T-T
Old 02-18-2011, 10:59 PM
Hi Mr. Penguin!
Drain the oil and strain the oil as it comes out through something like a cheesecloth- if the bearings did spin, you'll see the gold residue in the cheesecloth. This will save you pulling the pan off to check at the very least.
You might have gotten really lucky and just blown the bearings in one of the idler pulleys for your timing belt, as it can sound like a spun bearing.
Old 02-18-2011, 11:07 PM
3.3H6's Avatar
unfortunately all my tools are in the autotech building on campus, which is closed on weekends. I'll just have to drive/push it to norwich, and hope for the best...
Old 02-19-2011, 04:31 AM
immortal_suby's Avatar
Thread Killah
cracked flexplate makes for one hell of a racket too.
Locker Link
2015 BRZ Limited 6MT
Old 02-19-2011, 03:09 PM
3.3H6's Avatar
whatever it is, it's loud, noisy, and very disconcerting. If I need to replace the engine, I really don't know what I'm going to do, so don't be surprised to see a white 92 svx on craigslist for parts or best offer.
Old 02-19-2011, 08:18 PM
Jonnycash's Avatar
Jonnycash Jonnycash is offline
you can find a decent motor for under $500... swapping it should only take 4 hours tops. Its not all that bad
Giving money and power to government is like giving whiskey and car keys to teenage boys. – P.J. O'Rourke
Old 02-19-2011, 08:36 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
hope you fix her. :[ i'm a college student too, i feel your writing pain. don't sell the car. you'll regret it. :[
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 02-19-2011, 10:14 PM
Jake@FAPFab's Avatar
Jake@FAPFab Jake@FAPFab is offline
11.24:1 E85
$20 on #5 rod bearing.
Do yourself, and us, a favor by tearing that engine out asap to try to save the heads.
bummer.
Old 02-19-2011, 11:42 PM
3.3H6's Avatar
I take it to the dealership today, hopefully it makes it there. $500 doesn't sound like a lot of money, but its going to cut into my bank account badly, and I use that money for gas, insurance, fees, and food. not having a job sucks...
4 hours for a swap? maybe someone who's done it before....The only motor's i've pulled were from civics and integras.
Old 02-19-2011, 11:56 PM
Wikedjuggalo's Avatar
Rebuilding
Dear god why the dealership?
Old 02-20-2011, 12:25 AM
Cam Cam is offline
This engine is cake to pull and install. 4 bolts on the bellhousing, a few lines on each side, airbox, intake, battery, electrical disconnects, radiator and fans, dogbone brace, and BAM. She's out...
If you have a hoist and like, 15 different tools you can swap this engine out with little trouble. The dealer will most likely bring you to about $1000 all said and done IF you can get a decent engine for 500 bucks. At least try to find a reputable shop in the area. It would probably be $60-$80 an hour vs. $100
EDIT: last time I was at the dealership it was $600 for a timing job. I was just picking up parts but I made sure to let them know how ridiculous that was after I read it on one of their signs.
Cam
'92 Ls-L Dark Teal
