Old 02-16-2011, 09:51 PM
Subie-Addict Subie-Addict is offline
trans compatable?
Will an auto trans from a 97 outback sport wagon bolt into my 92 ls-l? There's a guy selling a reman with papers for 300$ no rear diff though. If it bolts up ill be pumped, but how do i find the trans ratio and how hard would it be to find a matching rear diff any thoughts?
Old 02-17-2011, 12:11 AM
Re: trans compatable?
If you are referring to an Impreza Outback Sport Wagon transmission, than yes it will bolt in, BUT the ratio, (if stock) is 4.11 to 1 and has not been found to be very long lasting behind our bigger engines/heavier cars.
In addition to changing the rear differential, you must NOT use the weaker torque converter and trade out the front speedometer sensor. (#2)
Old 02-17-2011, 06:04 AM
Alright thanks I just figured it was cheap enough to look into as my trans has 180k on it and I'm going to build the spare motor I bought for it some.
Old 02-25-2011, 03:45 PM
Ok found a rebuilt legacy outback trans and again the guy does not know the final drive or have rear diff. Correct me if I was mis informed but I was recently told all automatic awd legacy's in the mid 90s had same final drive? Is this correct and what is nthe ratio?
Old 02-25-2011, 04:08 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Grab the code off of the transmission bellhousing and throw it into google. Failing that, there is a transmission chart on my Impreza site, northursalia.com, that will give you all the info for a given tranny code.
Old 02-25-2011, 05:51 PM
All automatic Legacy Outbacks from 1996-early 1998 had the 4.44.
Just post the trans # here and make sure it does not have a factory spin on filter on the left side.
Old 02-28-2011, 08:12 AM
Subie addict Subie addict is offline
This is the ID he gave me # TZ102Z2CBA-BT
Old 02-28-2011, 10:33 AM
gbianchi gbianchi is offline
http://www.subaru-svx.net/forum/show...ght=TZ102Z2CBA
this should help........G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 02-28-2011, 12:15 PM
Cool beans I'll snag it this week, freshly rebuilt 4.44 should compliment my spare low milege motor nicely, powertrain swap here I come , now just need a rear diff to gut and I'll be golden
Old 03-15-2011, 03:18 PM
Stillhoff Stillhoff is offline
Will this trans build on to mt svx?
http://www.laga.se/delinfo.aspx?delindx=47023645
How expensive is it to have a svx trans rebuild?
What is it inside that gets damaged?
Valves, slides, pump or just every thing?
