Old 02-10-2011, 12:49 PM
Geoff's Avatar
Geoff Geoff is offline
Send a message via ICQ to Geoff Send a message via Yahoo to Geoff
Stupid ECU Question
Should an ECU from a '94 plug directly into a '92 without any issues? Any advantages/disadvantages to doing it?
Old 02-10-2011, 01:57 PM
Re: Stupid ECU Question
94 ECU will look for the EGR temp sensor reading I believe. The 92 federal ECU was the best one to use FYI...
Old 02-14-2011, 01:21 PM
Jake@FAPFab's Avatar
Jake@FAPFab Jake@FAPFab is offline
11.24:1 E85
yes, 94 will get pissed at no egr function
Old 05-21-2011, 08:46 PM
Geoff's Avatar
Just tried it! 94 ECU plugs into 92 car and works flawlessly. Just tried it. Did the ECU as well. Car runs MUCH, MUCH better with the 94 ECU with an EPROM on it that says "93 Cali / 94 All"
So, a 94 ECU will run a 92 perfectly.
Old 05-22-2011, 03:30 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Yeah. The ground wire for the EGR temp sensor is what switches to ECU to California mode. If you don't have an EGR temp sensor then the ECU pin isn't grounded and it uses 49-States mode, which is correct for a 92.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
