Old 02-09-2011, 03:31 AM
German axles.
Does anyone know if the front axles for a German SVX with an automatic are different from those in The United States?
Thank you,
Tom Krynock
Old 02-09-2011, 03:22 PM
Re: German axles.
Thank you,
Tom Krynock
Yes they should be the same be the same Tom, the German car used the same US type box.
Old 02-09-2011, 04:51 PM
Re: German axles.
Thank you Harvey!
I THOUGHT that they were the same, but after sending one to
Holland/The Netherlands, I am being told that it does not fit!
I am hoping to see a picture of them, side by side to compare the spline diameters.
The installer is convinced that I sent a rear axle by mistake.
The SVX is a Geman automatic 1992.
More as we figgure this out.
Old 02-09-2011, 06:04 PM
Re: German axles.
It is a bit of a mix match over there. Depends where it was first delivered and where it went from there.
These are the ones that I know.
VTD markets; Japan, England, Australia, NZ, Belgium, Luxembourg, Austria and Brazil.
US type markets; US, Canada, Germany, France, Switzerland.
No mention of what type for Israel, Thailand, Norway.
Old 02-21-2011, 02:40 AM
subaru subaru is offline
Re: German axles.
Hi Guys
Update about the axle
The axle itself fits, only the bearingrim on the OT axle has a width of 56 mm and the original axle is 60 mm
If the 56 mm is fitted, the bearing will stay open and will be destroyed in a matter of weeks
I have made a pic but have to remember how it worked
https://picasaweb.google.com/lh/phot...eat=directlink
Rinus
Old 02-21-2011, 09:44 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: German axles.
Why the different dia. bearings? is it because of gearbox variations - or something that Subaru did because of loadings on the splines?
Old 02-21-2011, 12:24 PM
Re: German axles.
Hi
Dont know about the bearings, it is the side of the wheel
The other thing is (not on picture) that the joint on the diff-side is thicker (more massive) than the OT one
Something else, the transmission gives a code 11, duty solenoid A
I cannot find where that is
Any suggestions?
Thanks
Rinus
