Old 02-02-2011, 02:19 PM
wolfboy wolfboy is offline
SVX door hinge replacment/repair?
Both of my doors need new hinges. The driver side is grinding and popping when I open it and close it. There's a lot of play at the point of articulation. What's the best way to go about replacing them?
Old 02-02-2011, 02:50 PM
kwren's Avatar
kwren kwren is offline
Re: SVX door hinge replacment/repair?
Is it actually the door hinges, the things that keep your doors fastened to the car to prevent the door from actually falling off, that are worn out on both your car
If you mean the "stabilizer" things that are spot welded on, there is a real nice easy fix for that.
Keith
Old 02-03-2011, 09:59 AM
It's the stabilizer on both sides and the driver side hinge is coming loose...
Old 02-09-2011, 03:42 PM
Maxo's Avatar
Maxo Maxo is offline
Sounds like you need new door checkers. I've looked into it before and they run around $35 apiece. Part# is 62090PA001.
If I had the time/inclination I'd fix mine too...
