Old 01-28-2011, 05:04 PM
Heli-Mech Heli-Mech is offline
Aftremarket fan = dead alternator.
I just finished wiring in a Flex-a-lite radiator fan on my eg33 swapped legacy. Ran the fan straight off the battery with a relay and spst switch.
-I tested evrything out and it was working great.
-Took the car out for a test run and the lights/stereo and gauges started to fade.
-I shut off the fan and accessories and headed back home.
-removed the fan wiring, and checked all the fuses and they are good.
-Tested the alternator and its only making 10 volts.....
Would the added load of the fan kill an alternator that was already on its way out?
Old 01-28-2011, 05:09 PM
Re: Aftremarket fan = dead alternator.
Maybe you had a short and that was what killed it?
Old 01-28-2011, 05:21 PM
Are you using a flex-a-lite controller and thermostat kit to run the fan or a manual use as needed switch?
Old 01-28-2011, 05:25 PM
Manual switch. Fan is run straight off the battery with a fuse and relay, switch controls the relay.
Old 01-28-2011, 07:14 PM
swapped it out for my spare alternator, this one only puts out 13.4v but thats good enough for now.
Now I have an issue with my CEL?
http://www.subaru-svx.net/forum/showthread.php?t=56463
