#31
Re: Power Steering - Hard-To-Turn!
dcb |
#32
What He said!^^^^^
#33
When I first started to fix my jerky steering, I added ATF (Redline brand, about $20/QT, should be overkill) to bring up low level.. Then, I tried Lucas PS Treatment (very viscous) for a while.. . Until I tried the replace O-Ring and flush suggestions here. Afterwards, it got better.. BUT REALLY BETTER after driving for 2 or 3 weeks!..?
SO, DO I HAVE EXPENSIVE FLUID THAT IS OK IN MY POWER STEERING SYSTEM (Power Steering fluid [Prestone]) .... OR DO I HAVE THE MOST DANGEROUS THING IN MY PS RESERVOIR.. THAT SHOULD BE REMOVED, FLUSHED, AND REPLACED WITH ATF AS SOON AS POSSIBLE.. ???!!! HEEEEEeeeeeeeLLLLLLllllllllPPPPPppppp!!!! Thanks, Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! |
#34
Just called the dealer here.. They said PS fluid OK!.. . ? My mechanic friend said shud B ok 2.. .
Hoping, Jim
#35
I have a reman. PS pump about 6 months ago and after reinstalled with new o-ring and whatnot it worked great without an issue for about a month before my timing belt broke.
Timing belt got replaced a little over a month ago and everything was great for a week then the squealing began. Figured it was because the belt was loosening so I tightened it. WD40'd the hell out of the pump and pulley and tightened a little more and it's helped tremendously but I also noticed the fluid was kind of high? (it seems hard as hell to tell how much fluid you're supposed to have in this thing) but after I turkey basted out about 5 sucks, it seemed to do a LOT better. I know the weather (low 20's, some flurries at times) probably had a huge impact on that but the root cause I still do not know. I still have some tolerance left on the belt to tighten and still have the half inch pushy down factor. I'm hoping it's just because their was too much fluid in it, which will... at least to my understanding, cause it to be sluggish and such. Otherwise, I'm clueless and will hopefully find an inexpensive means to getting it resolved.
1994 subaru svx le 112k |
#36
Went for another round and seemed I sucked too much out. Added just a little bit and now it doesn't squak super bad again like it did on startup the other day. Only time will tell but I fear it now is the rack/pinion ultimately causing the issue. It's fine after it warms up... and it was 70 out today so it was already warm so maybe that's why I didn't have any issues.
#37
Thank you very much for the info, I just ordered the part...not a bad price either.
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake. Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB Koni struts/ground control coilovers Stainless steel brake lines K&N filter, custom front grill H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w Clear front and corner lens |
#38
I did a little investigation today and I don't believe the crank pulley is the issue. When I turn the steering wheel the power steering pulley stops or significantly slows down while the belt continues to turn. I have a leak around the PS reservoir. I replaced the O-ring 6mo ago, but it was not the correct size. The O-ring will be replaced with the correct one at the local maintenance meet in the next month.
Any thoughts on what else would be causing the PS pulley to not be allowed to turn properly? Belts are not loose.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black 92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white. |
#39
Binding ball joint?
#40
If the power steering pump drive pulley is literally not turning, and you're certain the belt is tight and in good condition (which it won't be for long if the thing's dragging that much), I'd guess the pump is so far gone it's trying to seize.
To test the crank pulley make a match mark across the face of the pulley. I used a white wax crayon form my grandkids' Crayola box. Drive. If the rubber segment which joins the outer and inner components is separating, the mark will have become two marks. I've had the crank pulley fail on both of my cars. Last time, what alerted me to the developing problem was an awful screeching sound at startup, or when the PS was under load. dcb |
