Old 01-17-2011, 07:48 AM
Engine Diagnostic Tools
I am trying to determine the best set of Vacuum test and Compression test gauges...does anyone have a prefered set or recommend a particular brand? I've search online and have come across some as cheap as $20 and others as high as $350. I am just looking for something reliable and accurate. Suggestions would be greatly appreciated, thanks in advance!
Old 01-17-2011, 06:15 PM
Ironhydroxide's Avatar
Ironhydroxide Ironhydroxide is offline
SVXT6 Project
Re: Engine Diagnostic Tools
I've used my Snap-On compression gauge set for 3 years, bought it cheap (broken face glass) and it has never let me down. always been accurate. and came with 3 different hoses.... 10mm 12mm and 14mm
even buying it cheap, it was 150
SVXT6 (Pearly) just got running 201,000 (body) 105,000 (engine)
Honda FT500 Ascot [Red]
Old 01-18-2011, 04:10 PM
I have both the snap-on gauge and a cheap $20 one from harbor freight. I typically use the snap-on at work were I have to be accurate and the cheapo one at home were accuracy is not as key. The snap-on looks and feels better and even is slightly easier to use (better rubber that bends easier) but always gives me the same exact readings that my cheapo gauge does. If it's not going to make you money or your not going to use it very often I would recommend the cheapo gauge any day, had it for over 3 years and it still works fine.
