Old 01-17-2011, 11:26 AM
92 SVX 92 SVX is offline
Re: Fixed my stumbling idle- seafoamed the SVX today
Originally Posted by North Ursalia View Post
Updated the pic with part of one gratuitously stolen from 92 SVX that was posted in another thread .
lol Glad to be of help.
Old 01-17-2011, 01:06 PM
Huskymaniac's Avatar
Uses the ignore feature
So the answer is no, this will not clean the AACV when used at that location. However, you can still do so fairly easily. If you pull the vacuum line off of the driver side of the air inlet attached directly to the throttle bodies, this line goes right through the AACV, and then comes back up directly opposite where I was putting the seafoam in. Save a little bit and pass it through here and you'll be good. Hell, you can put it straight in here if you like instead, as it will end up in the same place.
Now the only question is, is the AACV open when the engine is cold or when it is hot?
Tony
Old 01-17-2011, 01:28 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
The AACV only allows bypass air when the engine is cold
