Old 12-13-2010, 11:55 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Option for pedal set for wireclutch.
I just woundring about one thing. I have try to get my Clutch pedal little harder. But whit no luck so far. Are the some one here that have a good solution for that. I cant use the oem spring from the old Legacy that i have take the pedal set from. I used a 1990 Legacy.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 12-13-2010, 04:25 PM
yota-toy's Avatar
yota-toy yota-toy is offline
Re: Option for pedal set for wireclutch.
Are you having problems with the pedal returning? How long ago did you do your swap. I know when I did my swap the pedal stuck but that's cause it was cutting into the wiring brick above the pedal assembly. I used the pedals assembly and brake booster from a '96 Legacy, everything seem to work ok.
Everything must be Modified!
Old 12-14-2010, 12:32 PM
Alex-svx's Avatar
Nope the pedal is returing. The car is placed inside for the winter.
But i have drive it in the sommer time. And the pedal feel little shoft. I really want it to bee little harder to push.
But have you used some spring on the clutch pedal?
Alexander (Norway)
My subarus:
Old 12-14-2010, 04:40 PM
yota-toy's Avatar
hmmm, the only way to correctly change the pedal pressure is to put a stiffer pressure plate on the clutch. I guess you could change the position of the cable on the pedal however that will shorten your throw.
Old 12-16-2010, 02:25 PM
Alex-svx's Avatar
Ok. Thanks alot for the answere.
Alexander (Norway)
My subarus:
