Old 11-27-2010, 02:11 PM
92 SVX 92 SVX is offline
Cost of replacing Duty solenoid C
Does anyone have any idea of the cost to replace duty solenoid C and the transfer clutches?
my solenoid c is not working at all and it has the 50/50 locked in and obviously turning is wearing out the clutches I have driven this far longer then intended and the clutches are grinding fairly noisily now.
Old 11-27-2010, 05:03 PM
Re: Cost of replacing Duty solenoid C
I have a knowingly good used set of transfer clutches plus the C sol.
It's not hard to do yourself, otherwise for a shop to do it, it is about 3 hours of service roughly...
Old 11-27-2010, 05:09 PM
Cam Cam is offline
If the OP is not interested in your clutchpacks and sol c, I am interested in taking them off your hands. shoot me a PM if you want to get rid of them.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 11-27-2010, 05:14 PM
I just had mine done. About 3 hours work plus $150 in parts.
$100 for the solenoid, $30 or so for the transmission fluid, $20 for the gasket. I had a few exhaust bolts and gaskets that also had to be replaced too.
Old 11-27-2010, 07:16 PM
I would do it myself but I just moved and have no real tools nor shop or even garage. I am very interested in the parts though, what are you asking for price, and shipping?
zip would be to 32211
Old 11-27-2010, 09:25 PM
That sounds about right!
Old 11-27-2010, 09:40 PM
Thanks again Tom, that little solenoid makes a big difference.
Old 11-27-2010, 10:19 PM
Good to hear!
We want them to live forever!
Old 11-29-2010, 01:07 PM
ok, I have been looking for the gasket that sean mentioned and I can not find it
does anyone know the part number?
Old 11-29-2010, 04:30 PM
1) 31337aa120
1) 31952aa030
2) 31954aa071
Old 11-29-2010, 05:48 PM
1) 31337aa120
1) 31952aa030
2) 31954aa071
hey what is the plate transfer valve and gasket, and do I need them?
Old 11-29-2010, 08:57 PM
The gaskets, yes!
A new plate will make your life easier.
It is like $3.00.
There is/are more things that you can replace while it is apart.
Things that you SHOULD replace,
while you are down there.
Old 11-29-2010, 11:59 PM
ok thank you
