Old 11-15-2010, 06:46 PM
cruisen_15's Avatar
Re: eg33 swap wont rev
uhhhhhg, so i swapped the 2 wires to my ignition module, it was worse
so my wiring on that was already in correct place and the fsm has the colors wrong then,
messed with the wiring to maf some more, any other way than 1 (which i believe to be correct) it wont even stay idling,
so she runs at 1000rpm..... just sits there and i can feel a slight knock/misfire but still with any gas she ****s on me. maby i do need to hookup some 02's and let it sit for a bit.
also i dont have the svx injectors installed, i used the ej25d legacy red injectors.
Old 11-15-2010, 08:54 PM
The SVX uses red injectors, unless you upgrade.
Old 11-15-2010, 09:15 PM
cruisen_15's Avatar
yeah the ej25d injectors are also red, both are 270cc i believe
(didnt have svx injectors)
Old 11-15-2010, 09:37 PM
If I remember correctly 275.
Is your 3.3 a turbo?
Or does that come later?
Have you had the engine apart?
If so to what extent?
Old 11-15-2010, 09:38 PM
cruisen_15's Avatar
ahhh yes, thats right i knew it was one of the two
Old 06-29-2011, 11:27 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Yeh, vintage thread, but it's the only one I found with mention of my topic and it's pertinent to this one.
Does our EG33 actually have a RECIRC GAS TEMP SENSOR? Contrary to the FSM (which is alllllllllways accurate ), the "upper" engine harness (mounted to the bottom of the intake manifold) doesn't seem to support one!
Old 06-29-2011, 01:06 PM
LetItSnow's Avatar
Per <this Emission and Vac pdf>, it's California only.
