Old 10-28-2010, 11:19 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Mysterious Crackling Sound?
okay, so this rarely happens. but when it's really moist outside (long rain, snow, really cold, etc.) my car makes a really low crackling or clicking sound from the front wheels. it kinda sounds like the suspension is lose by 1mm of something, and it's only at super low speeds (<10mph) while i'm turning sharply. i can feel it on my feet too. it has never seemed to worsen, and i think it's been like this since i got the car. it's never caused any other problems either. is it a CV joint? if so my warranty covers it.
also, could it be linked to this? whenever i go over abrupt bumps in the road, my suspension seems a little loud. is it just the nature of this 19 year old car to be that way? or is it something wrong? someone must be going through this, i'm stumped. i've had my car worked on my numerous people and they've never told me anything was loose either.
suggestions?
if it's something expensive i'll just deal with it, cause it has never got any worse whatsoever.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 10-28-2010, 11:34 AM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Re: Mysterious Crackling Sound?
I'm not sure about the clicking/crackling you're experiencing, but my guess on the loud suspension is worn strut mounts; that is typical of a 19 year old car. I had the same problem on my old claret.
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 10-28-2010, 11:41 AM
B 4 You's Avatar
#lolsvx
are worn out strut mounts a bad thing? like. no one else ever notices it, only me because i'm paranoid that my car will crack in half if i hit a pothole. but that's just me.
how much are the strut mounts?
i'll have to check that stupid warranty...
also, the back ones are a little loud too.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-28-2010, 01:48 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
You can get 18 year old Subaru strut replacements for $124.00 each but they are bad on arrival. Ask me, I have 2.
How does the mount wear? Mine look great.
Gene
Gene and Ben
Old 10-28-2010, 02:02 PM
B 4 You's Avatar
#lolsvx
how does the what..?
and are those brand new ones?
also. how hard of a job is this? i don't have labor rates in my budget.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-28-2010, 02:40 PM
B 4 You's Avatar
#lolsvx
according to , that popping sound is my CV joints going. i'm covered for those. but, shouldn't they do that all the time? it seems like it will do that slight popping sound 1 out 100 low speed turns while it's dry or hot out. yet like 90 out of 100 it will make that sound while wet or cold.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-28-2010, 02:43 PM
Mike621 Mike621 is online now
The creaking/clicking while turning is a sign of CV axles that could need replacement.
I also suggest reading up on symptoms of front end suspension, cv, etc failures by searching.
I'd suggest checking out svxfiles.com or PM svxfiles and think about taking some time to have your car checked out by him, as he is about two hours or less from where your location is listed.
Old 10-28-2010, 03:08 PM
B 4 You's Avatar
#lolsvx
yes i've talked with him before :] i think i can get my money back from that damn warranty. paid $1300 for it, got maybe $200 out of it when i replaced my entire cooling system. if i can get even $800 for it then heck, i'll put $800 into my car.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-28-2010, 04:23 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Gene
Whuuuuah? I have read this response 30 times. What does it mean? Why would you want to buy 18yo strut mounts? Can you get new ones? How does the mount wear, mine look great? Huh? I am not being rude, I just want to understand.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 10-28-2010, 06:18 PM
tiv0's Avatar
svxless
What Gene is saying is that you can order the stock struts for the SVX from Subaru, but they are 18/19 year old struts, meaning they are no longer 'great' quality.
His comment on the strut mounts wearing was in regard to my suggestion of replacing the strut mounts. When my front suspension would rattle over bumps, it was the strut mounts I had replaced and that fixed the problem.
Hope that clears it up.
Trevor
Avondale, AZ
1987 BMW 325is
Old 10-28-2010, 06:35 PM
BRADY's Avatar
SVX Addict
It makes it crystal clear. Thanks mate. My car is suffering from a similar problem. I figured it is the strut mounts. So, last question: what strut mounts are on the market today and where do I find them?
Thanks
Mike
Old 10-28-2010, 06:45 PM
tiv0's Avatar
svxless
Thanks
Mike
Not too sure. Mine were Subaru parts purchased from the dealership. I am not familiar with the amount of work and $$ involved as my stepdad took care of this issue with our old SVX which I no longer have the maintenance records/receipts from.
Trevor
Avondale, AZ
1987 BMW 325is
Old 10-28-2010, 09:50 PM
B 4 You's Avatar
#lolsvx
well i'd like to get me some new struts. it sounds like i have some cheap car with a loud cheap suspension, yet it's like the smoothest ride of all time.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
