Old 10-24-2010, 05:15 PM
Black88GTA's Avatar
Black88GTA Black88GTA is offline
look like a leprechaun to me
A little help with engine removal...
So last weekend I decided to finally pull my engine so I could replace the head gasket that went back in March. I started taking everything apart, and everything was going more or less OK, until I got to the point where the engine had to separate from the transmission so it could come out. Here is the car as it currently sits:
I removed everything holding the engine and transmission together, but I can't get them to separate no matter what I do. What am I missing here? Is there some kind of trick to this that I don't know about?
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road.
Old 10-24-2010, 05:26 PM
Cam Cam is offline
Re: A little help with engine removal...
Did you separate the engine mounts from the crossmember?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 10-24-2010, 05:44 PM
Black88GTA's Avatar
Yeah, I have it so that when I hoist the engine up I can move it around. It's completely free of the car , but won't break free from the transmission.
Old 10-24-2010, 07:22 PM
immortal_suby's Avatar
Thread Killah
you unbolted the flexplate, right?
Locker Link
2015 BRZ Limited 6MT
Old 10-24-2010, 07:25 PM
Cam Cam is offline
It may help to loosen your tranny mount. I suspect the transmission is restricting the engine from lifting enough to clear the bushing studs from the crossmember. You need the studs to clear so you can slide the engine studs (threaded into the bottom holes on the backside of the engine) out of the bellhousing on the trans.
Cam
'92 Ls-L Dark Teal
Old 10-24-2010, 07:30 PM
Black88GTA's Avatar
Yep...got the 4 flexplate bolts, both starter bolts, the nuts on the studs at the bottom, and the remaining bellhousing bolt on the top passenger side. I have a full set of the factory service manuals, and went through the procedure top to bottom, and made sure to remove every fastener it refers to, but there must be something I'm missing...
The tranny was upgraded to a 4:44 less than 2 years ago, and the car has probably seen ~10k miles since then, so it shouldn't be seized in there or anything like that. I just can't figure it out.
Old 10-24-2010, 07:32 PM
Black88GTA's Avatar
This is a good idea, thanks...I haven't touched the trans mount. Will try that next. I probably won't be able to get to it until next weekend though, unless I start taking vacation days - which I just might, if it's nice out.
Old 10-24-2010, 10:53 PM
BFH, flathead screw drivers of various sizes, and prybars... Even if the engine and trans were apart just months ago, unless you put antisieze, and even if you did, it still will sieze back together. Its just what happens when you mix aluminim and steel
Old 10-25-2010, 12:33 AM
If I am not mistaken, there are studs between the engine and tranny.
I assume you removed the bolts, but the studs are holding them together?
Old 10-25-2010, 01:11 AM
Black88GTA's Avatar
I tried banging on them and prying them a little bit, but not too hard because I didn't want to damage the parts - plus, I wasn't sure if there was something still holding them together. I'll try again and put a little more force on it when I attempt this again.
Yep, there are two on the bottom - I pulled the nuts off of those. The transmission is just supposed to slide off once the nuts are removed, right?
Old 10-25-2010, 04:44 AM
If you got the 2 nuts on the studs, and the 2 long bolts up top, you got them all. Lower it back onto the engine mount, and use a chisel to start a crack, then screw drivers and pry bars to spread the crack.
Old 10-25-2010, 07:19 PM
what hocrest said. Sorry, it`s just a little hard to type out long responses on my phone. Don`t worry about making marks on the bellhousing. It`s not going to do any damage that affects anything
Old 10-26-2010, 10:30 PM
Black88GTA's Avatar
Well, it's finally out! Thanks to all who responded. A bit of SiliKroil and some wacking on it with a knife edge sharpened chisel and bigass hammer did it. Used a lot more force this time, since I was sure there really wasn't anything else holding it together.
