Old 10-18-2010, 06:12 PM
SomethingElse's Avatar
word words wording
Broke My Manual Trans Question
So like ...I was being stupid as usual and screwed up my $1600 06 WRX manual trans. I did a reverse burnout in a body shop...typically the floor is covered in dust so its safe. Well my tires had wet on them from washing the car and the tires hopped until a terrible grindy noise suddenly appeared.
The noise only happens in reverse. No forward gears make any abnormal noise.
So my question is after I do a drain and fill and fish the metal out can I expect this thing to not explode in 1k miles? obviously a tear down is in the near future but I don't wanna miss the pumpkin carve.
Also where can I get manual trans parts from? Thanks in advance.
please feel free to call me stupid names...I deserve this one
Eric
Old 10-18-2010, 08:25 PM
Re: Broke My Manual Trans Question
Dat **** is broken... prob ur headgaskets
Old 10-18-2010, 08:26 PM
word words wording
****tard
Eric
Old 10-19-2010, 03:18 PM
hahahahhaha
Old 10-19-2010, 04:01 PM
jackleg 123
Old 10-19-2010, 04:10 PM
Gamesy's Avatar
Gamesy Gamesy is offline
looks like you'll just have to open it up and put in a new reverse gear, guaranteed the sprocket is strippe
it could be done in a day's work
Old 10-19-2010, 05:04 PM
word words wording
Ive heard the same thing from a couple people...Im just gonna do the flush for now drive it up to the pumpkin carve and stay out of reverse whenever possible. Im guessing I can only get parts from the dealer. Ive tried to a few different times with no luck.
75-90w gear oil was it? I dont remember how many quarts.
Eric
Old 10-19-2010, 11:10 PM
Gamesy's Avatar
i think its 75-90w i used lucas synth, and its 3.78l so a gal, pick up 4 quarts and you should be good. i wish you luck that whatever sheared off the reverse gear does destroy the others.
Old 10-20-2010, 04:23 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
there should be plenty of people to push you backwards at the pumpkin carve . Good luck. Hopefully the fix isn't too expensive
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-20-2010, 05:50 AM
kcbsvx's Avatar
kcbsvx kcbsvx is offline
Now down to only ONE!
Check to see if 1stsubaruparts.com has your trans parts. I just bought a bunch of timing belt covers, bolts and seals from them at about 1/2 of the prices my local dealer quoted. Very friendly, patient and informed people there.
More on the dealer later; AFTER I get my car back.
Enjoy the PCarve.
Christian-
96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC.
2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock
1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods
2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock
Old 10-20-2010, 04:40 PM
word words wording
Thanks guys.
I did the drain and fill today. No metal came from the drainplug...stuck a magnet in there to try and hook some but no bites. Used a blow gun to try and find some but again, nothing.
I cant help but think this is a bad thing. If something is loose in there it shan't end pretty. When I find out hopefully it wont be the hard way
Eric
Old 10-20-2010, 09:08 PM
Like I said may have just nicked a gear and its just making a Rukus... Or its headgaskets
Old 10-20-2010, 10:21 PM
Gamesy's Avatar
why would headgaskets only cause noise only in reverse?
Old 10-20-2010, 10:56 PM
Old 10-21-2010, 05:15 AM
The gaskets see pressure in different areas when the engine turns the other direction.
tee hee hee
