Old 06-10-2010, 08:15 PM
Is there any difference between a LR and RR Strut
Through a series of confused and messed up transactions, I ended up with 2 replacement left rear struts and no right rear. As far as I can see the only difference between a left and right is the two mounting points for the brake lines.
They can be easily cut and re-welded. Is there another difference that I'm not aware of.
Old 06-11-2010, 05:16 AM
Re: Is there any difference between a LR and RR Strut
They are the same except that brake line mount...be careful welding on them as they are pressurized....
Old 06-11-2010, 09:51 AM
NeedForSpeed NeedForSpeed is offline
The top mounts are not interchangable either
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 06-14-2010, 08:22 AM
Anyone else with insight.
Old 06-14-2010, 09:13 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
The above should answer your question. It will not bolt up to the holes at the top correctly as the mount is different. Bottom line---IT WILL NOT WORK unless you change the top mount AND the weld location of the brake line mounts.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-14-2010, 10:34 AM
Perfect. I was just confirming. I'll see what I can do with the part swapping.
