Old 05-14-2010, 02:16 PM
GgabrielBenitez GgabrielBenitez is offline
Rear passanger brake caliper.
Mine if FROZEN stuck onto the rotor. I'm gonna need a new one, or suggestions on how to fix the old one.
Old 05-14-2010, 02:20 PM
sicksubie's Avatar
Re: Rear passanger brake caliper.
I have one and will be in rochester in 3 weeks if you want to wait that long...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
sicksubie's Avatar
June 3-6th to be exact
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 05-14-2010, 03:11 PM
Rock Auto has rebuilt's for $40-50.
Last time I did mine and had to replace one, I found that Legacy rear calipers are a direct swap.
Old 05-14-2010, 03:17 PM
I can wait. I'd also like to see your SVX. I never really get to see any.
Old 05-15-2010, 08:29 AM
It might be the brake line. When too much dirt gets into the rubber lines, they can clog causing the pressure to not be released and you get a seized caliper...
Old 05-15-2010, 08:40 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
There are some pretty strong arguments for rebuilding or replaciing BOTH axle set calipers. Not mandatory, but recommended particularly in high rust areas.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 05-15-2010, 11:52 AM
How do I go about cleaning them?
Old 05-15-2010, 11:56 AM
I would either get a new one or rebuilt one and I would replace both of them instead of just one. The other option you have is to rebuild them yourself. There is a How-To in the forum that tells you how to do it and the parts that you would need.
Old 05-15-2010, 01:30 PM
You replace the brake line
Old 05-19-2010, 08:40 AM
How hard is this? Shouldn't be too hard right?
Old 05-19-2010, 09:11 AM
Not hard at all. Brake lines clog in the soft rubber hose part, never in the hard lines if this is in fact the problem. You could use this opportunity to just go ahead and get stainless steel lines. You can get them off of ebay for around $80 shipped for all 4 I believe. If you still have a problem, then replace the caliper.
Old 05-26-2010, 07:42 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I've got a similar issue with my left rear caliper. Would it be ideal to replace the rubber hose there too? And what is a part number for the hose if anyone knows?
1995 Subaru Svx L / AWD
Old 06-02-2010, 02:42 PM
Schralper's Avatar
Schralper Schralper is offline
just buy rebuilt ones and replace. i just did my rears due to calipers not releasing. is that brake is smell? oh look smoke off the rear rotor.
mine came w/ mounting brackets to.
just let fluid run thru for a lil bit to flush no need to "bleed" brakes if you don't hit the brake pedal while working on it.
don't to forget to release booster residual vacuum.
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
