Old 04-27-2010, 08:58 PM
skylimey skylimey is offline
Engine Revolution Signal (code 23)
Sometimes (so far only once per trip) during my commute, when the engine is idling as I coast in traffic (ie less than 10 mph-ish), in 'Drive (D)' the engine stalls and the car keeps coasting.
When I put the gear selector in N and crank the engine it starts fine and doesn't seems to fail again.
Transmission error code is 23, Engine Revolution Signal.
So, question, any idea's what causes the engine to stall (maybe the engine stalls which causes the 23, or maybe the 23 stalls the engine?) and if so, any clues to a fix.
I tried to search the forum but didn't find an answer.
Thanks
Martin
95 SVX L 170K miles
95 SVX LSi (sold)
92 SVX LSi (sold)
Old 04-27-2010, 09:31 PM
Re: Engine Revolution Signal (code 23)
Engine code 23 is for a bad MAF sensor. I don't know what you mean by "engine revolution signal". Also the symptoms you are experiencing also point to a bad MAF. Try cleaning it and if that doesn't have an effect, check to see that the soldered connections are still all in tact by opening it up. If you use a K&N filter or similar filter that uses oil on the filter, cleaning the MAF should correct your problem.
Old 04-27-2010, 10:20 PM
OK, thanks I'll check the MAF Sensor. I got the "Engine Revolution Signal" from a pdf posted here abouts by FSM.
Thanks again.
Martin
95 SVX L 170K miles
95 SVX LSi (sold)
92 SVX LSi (sold)
Old 04-28-2010, 05:15 AM
If it is a trans error code, it does require the input of the engine RPM signal..> This might be lost when you stall. Check the engine codes for why it is stalling
Old 04-28-2010, 11:27 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Yes. The TCU gives code 23 if the engine stalls.
In my case it was due to bad fuel.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-28-2010, 04:38 PM
Ahh crap, it was a TCU code, not ECU... sorry skylimey
