Old 04-20-2010, 06:21 PM
radarwhiz's Avatar
Fairmont State University
valve "ticking"
Any advise on the best fix for valve 'ticking', what I'm guessing is a collapsed lifter?
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-20-2010, 06:49 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: valve "ticking"
It's weird.. I get that on and off sometimes..
Old 04-20-2010, 06:52 PM
Re: valve "ticking"
Drive the piss out of it and it might go away... just from sitting for an extended amount of time. It's not going to cause any damage and your looking at disassembling the top end to truly take care of it.
Others may suggest seafoam or other "fixes" but I personally wouldn't want to go that route.
Old 04-20-2010, 06:58 PM
radarwhiz's Avatar
Re: valve "ticking"
That's what I thought I would do and if it is a collapsed lifter maybe high RPM (higher oil pressure) would fill it back up.
By the way, how was your drive back home, Nate?
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-20-2010, 08:01 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: valve "ticking"
Mine comes and goes also..... someone suggested "valve medic", anyone else heard of that?
Old 04-20-2010, 08:54 PM
redlinedeath redlinedeath is offline
Send a message via AIM to redlinedeath Send a message via Yahoo to redlinedeath
Re: valve "ticking"
mine seems to come and go at will, its strange. before, it did it all the time, so before i got it off jackstands and on the road, i put half a can of sea foam in the oil let it run for a while, reved it up a bit(really, just a bit) drove it around when i got it on the ground, changed the oil, and now its smooth with the occasional tick.
we sell valve medic at work, but its the same deal as the seafoam, use too much, and your turning your oil in to water. ive heard of people spinning bearings, but i cant confirm this. just dont use more than the suggested amount. as for the seafoam, only use it for a few hours to the day before your oil change to be safe. but im not condoning either treatment, use at your own risk. my motor ticks very minimaly now if it does. but i wont know its condition for a few more weeks of driving.
Old 04-20-2010, 09:21 PM
Re: valve "ticking"
Yeah, it will go away when oil pressure comes up and the oil thins out from the heat as well.
It was a nice drive back other than being way too tired but that was my own fault. Had a great time meeting up with a few SVX owners in Indianapolis and no issues at all with the car on the whole trip other than having to add some ATF to the power steering in Indianapolis as it started groaning as I went to leave. It was nice meeting you as well as the others that I met for the first time. I think I really should start a thread on everything I did along my whole trip... might be a long post though.
Old 04-21-2010, 03:39 PM
immortal_suby's Avatar
Thread Killah
Re: valve "ticking"
I've had great luck with a quart of motor oil cleaner. There are a few different brands, Usually you add one to your oil and run for a few minutes and then do an oil change. One engine that had sat for a long time and clattered like mad cleared right up after thetreatment. The other had just began to clatter on and off and the treatment fixed it too.
Locker Link
2015 BRZ Limited 6MT
Old 04-21-2010, 07:56 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: valve "ticking"
And if you really love your car, you might consider two oil changes after using the stuff as some detergent will be left behind to mix with the oil after the first one.
