Old 04-12-2010, 12:21 AM
redlinedeath redlinedeath is offline
Send a message via AIM to redlinedeath Send a message via Yahoo to redlinedeath
gc question
i hope i posted in the right section first off, because its a suspension question, but its still technical q&a, so i apologize if im in the wrong section!
anyhow, so im curious as to why you cant use the ground control springs on stock struts. how does it destroy the strut? aside from welding, i can imagine the results there, but what does the higher spring rate do to the strut?
-Raul
Old 04-12-2010, 11:34 PM
Re: gc question
nothing? anyone? hello? harro?
Old 04-15-2010, 07:17 PM
skuby98 skuby98 is offline
Re: gc question
if you looking for the gc chasis question place, i would say go to NASIOC.com or to RS25.com.
but the best i can do to tell you is it will cause premature failer on your struts. how i don't know.
james
1998 Subaru Impreza 2.5rs coupe.
but now it is soon to be a Rsvx....but rewiring sucks....
Old 04-15-2010, 07:36 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: gc question
I'm pretty sure he meant Ground Control by "gc", and not the pre-2002 Impreza platform.
Old 04-25-2010, 12:12 AM
Re: gc question
LetItSnow is right, sorry!
Old 04-25-2010, 06:10 AM
michael's Avatar
michael michael is offline
What Potholes ???
Re: gc question
I am no expert on this by any means, but I'll take a guess. OEM struts aren't built to be able to control the movement of the GC spring rates. They would have to work too hard and ineffectively which would shorten their life.
Wanted: Steering Wheel
Old 04-25-2010, 01:00 PM
Re: gc question
^^^This. The OEM shock valving (which is also quite old and tired) can't handle the rebound speed with which the much stronger springs will extend the shock after a bump. It'll work for a while, but eventually... Not so much. Plus if you're going to an aftermarket spring you probably want the adjustable dampers to go with it.
Old 04-25-2010, 11:07 PM
Re: gc question
hmmm... when i break, even lightly, the car dips like crazy. going up parking lot enterances, unless i slow to a crawl and not touch the brake at all, something bottoms out. struts? springs? gremlins in my engine bay?
Old 04-25-2010, 11:48 PM
Re: gc question
Bounce the front of your car (push down on the bumper, or open the hood and push on the rad support) and see if it settles immediately or does the waterbed thing. The car should immediately return to it's original height with no up/down bouncing on it's own. If it does continue to bounce it's an indicator that your front shocks are done.
Here's a video of what to look for (don't go as nuts as this guy). Note how long it takes the car to stop bouncing.
Old 04-27-2010, 11:07 AM
Re: gc question
hahaha, good video. ill give that a shot, which is sad, because im familiar with this test, and didnt think about it.
Old 04-27-2010, 05:18 PM
michael's Avatar
What Potholes ???
Re: gc question
or try this
http://www.youtube.com/watch?v=TBLdJYvizQo
