Old 04-06-2010, 08:30 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
speed sensor swap
My mechanic is swaping out my trans to the 4.44. His question is about the speed sensor. Something about three wires on one and two wires on the other. Can someone explain what needs to be done to make it work? Thanks!
Old 04-06-2010, 08:35 AM
Re: speed sensor swap
take the speed sensor off of your sxv trans and put it onto the new trans.
Old 04-06-2010, 09:42 AM
Unfortunatly the SVX speedometer will read 5.5% higher than actual.
Old 04-06-2010, 10:46 AM
gbianchi gbianchi is offline
5.5% higher than actual. So its like going faster without the risk, COOL..........G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 04-06-2010, 11:24 AM
dannmarr's Avatar
I work for my SVX
My mechanic called me and said he can't understand how it comes out of the trans. Can anyone can shine some light on this? Are there screws, brackets, twist and turn, pull, release button, etc.? Any 'how to' or photos?
Old 04-06-2010, 11:57 AM
Use an open ended wrench. Either 12 or 14 mm. Can't remember. It just twists out...
Old 04-06-2010, 07:38 PM
it's a 17mm wrench needed to turn it out, the entire sensor unthreads
Old 04-06-2010, 11:11 PM
wow my memory is horrid I just did it last weekend.
Old 04-06-2010, 11:27 PM
WOW, Someone shopuld writer a How Too.....
Look down, Really!
Old 04-07-2010, 04:11 AM
dannmarr's Avatar
I work for my SVX
I had to go see for myself. When he unscrewed it, the inside stem did not come out with the sensor. He didn't want to just pull it out without knowing it's shape. He was being careful not to break it. He did finally get it all out. Thanks for the responses.
Old 04-10-2010, 01:52 PM
sowise sowise is offline
ha I had the same issue when I removed mine the stem and seal didn't come with the sensor and I was thinking damn another part i gotta order even began looking for parts but in the end I got it all figured out. I just didn't expect it to come out in seperate pieces either. Anyway good luck with your 4.44 swap.
