Old 04-01-2010, 03:47 PM
httrdd httrdd is offline
Radiator alternatives?
The stock radiator and fans are too big for my Eg33 swap. What are the other alternatives for a more compact radiator? What other models fit well? Any help will be apreciated!
Old 04-01-2010, 03:52 PM
Re: Radiator alternatives?
What are you swapping into? We're mostly interested in what fits the SVX, so you're going to have to measure your car and see what's available for it.
Old 04-01-2010, 04:24 PM
99 LGT
What is my best way to size it though? Do I take a BTU rating and a CFM rating? I found a couple that might work with low profile fans.
Old 04-02-2010, 04:07 PM
Bumpity!
Old 04-02-2010, 04:10 PM
You will have to custom fit slim and effective fans instead. The EG33 will not work with any smaller rad than the stock.
Old 04-02-2010, 04:37 PM
michael's Avatar
michael michael is offline
What Potholes ???
I've seen a few different options, not sure if I'd recommend some. Stock Leg or SVX rad moved forward cutting the rad support out. Same rads, in front of the rad support but mounted lower than stock. Finally, smaller custom rad moved forward not cutting the support. Some of the methods required either slim fans or pusher fans in front of the radiator.
Wanted: Steering Wheel
Old 04-03-2010, 10:13 AM
Thanks for the info. I hear older rx-7s and Sabb 900s work too. I just need to get the cooling amount needed from a Eg33 to size up other radiators.
Old 04-09-2010, 03:24 PM
Can someone give me the dimentions of a stock 92 svx radiator?
