Old 03-26-2010, 10:48 PM
kwren's Avatar
kwren kwren is offline
HID fog lights
3,000 or 4,000??
Thanks
Keith
Old 03-26-2010, 11:51 PM
Phat Ride's Avatar
Phat Ride Phat Ride is offline
Re: HID fog lights
3000k
By Faith Mayonazzzz!
_________________________
1992 Subaru SVX Pearl White LS-L 128k #7234
1992 Subaru SVX Pearl White LS 145k #2896
2006 Subaru B9 Tribeca Blue Pearl Limited 36k
Old 03-27-2010, 12:16 AM
Coan's Avatar
Coan Coan is offline
Alleged User
Re: HID fog lights
I see DDM Tuning dropped their prices on their kits to $35. Maybe I will do the fogs after all...
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
Old 03-27-2010, 12:26 AM
Re: HID fog lights
5000K
Beam pattern: 5000K HID Low Beam and 5000K HID Fog Lights
Old 03-27-2010, 08:37 AM
ZMan's Avatar
ZMan ZMan is offline
Re: HID fog lights
+ 1 on 5000K Has the whitest color and the most light output.
Old 03-27-2010, 09:06 AM
Phat Ride's Avatar
Re: HID fog lights
5000k fog lights are very white and look great, but true fog lights are yellow.
Old 03-27-2010, 09:15 AM
ZMan's Avatar
Re: HID fog lights
Your right - I was actually referring to headlights.
Old 03-27-2010, 10:04 AM
Coan's Avatar
Alleged User
Re: HID fog lights
My 5000k's seem a little bluer than those posted above, I wonder if they may have shipped me the wrong ones? I was actually a little disappointed in how blue they were, and was hoping for more of a pure white... is there any way to tell what ones I have?
Jon
Old 03-27-2010, 10:40 AM
ZMan's Avatar
Re: HID fog lights
A link to an HID color chart: http://www.delonixradar.com.au/hid-x...lour-chart.php
Old 03-27-2010, 10:55 AM
ZMan's Avatar
Re: HID fog lights
Just looked at 2 extra bulbs I have and they had no color marking on them, but on the plastic protective covers they were marked with the color temp. -
but that could be put on any bulb.
Old 03-27-2010, 03:25 PM
Re: HID fog lights
Originally Posted by kwren View Post
3,000 or 4,000??
Thanks
Keith
Keith
Most fog lamps including ours tend to scatter the available light low and wide. The object of this is to illuminate the road close to the car and to illuminate the verge, to help you keep your vehicle in the correct position in your own lane while you make your progress through the poor visibility.
If your fogs had actual so called "driving" lenses then the main light beam from these would be higher and forward. A very intense bright white lamp firing directly forward could in certain circumstances [such as heavy snow] create a lot of reflected glare which will in turn adversely affect the vision of the driver trying to peer through this glare. For that glare reduction reason it was traditional in fog lamps to use yellow beams as the lower frequency yellow light is known to be better at penetrating and to be less prone to glare.
However it's my opinion that if your fog beams are correctly focused low and wide [as the fog beams from the SVX are usually correctly focused] then you should avail of the highest light output you can get simply because there will not be a lot of the reflected glare the old yellow beams were meant to defeat.
So my vote would be #1 for the 4300K HIDs or #2 for the 5000Ks that John uses. I would not bother with the 3000s.
Old 03-27-2010, 05:57 PM
kwren's Avatar
Re: HID fog lights
I did the 5000 fogs originally on my hi mileage SVX and they light up the world great!
Thanks for the input everyone!
Keith
Secondly, the supposed 5000 that is too blue sounds like they sent 6000 instead of what was ordered.
Old 03-27-2010, 08:57 PM
Re: HID fog lights
In very bad /heavy snow, I disconnect my headlights and drive with only the foglights.
Easy to light the roadway in front of me (as my speeds are slower) without having reflected glare from headlights reflecting snow back into the windshield abd reducing my visability.
The foglights are easily visible to oncoming traffic without unwanted glare into the eyes of opposing traffic.
Will be running a dedicated circuit to the foglights for this purpose, as disconnecting my headlights also leaves me without high-beam capabilities.
Old 03-31-2010, 11:17 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: HID fog lights
I don't want to hijack but I don't think its necessary to make an entirely new thread for my question..
On the DDM Tuning website, which kit should be ordered?
I was looking at the "DDM HID KIT SLIM BALLAST (35W)" but I don't know what bulb type I'd need (H1, H3, H4, etc) or if 55W would be fine for fog lights? I was thinking 35W cause they are less intense.
I want them to look just like my headlights at 6000k.. or I think they are. (Installing other fog lights at the bottom of the bumper later)
These are mine.. Look like 6000k or 8000k?
EDIT:
Also looking at "APEXCONE RAPTOR HID KIT (35W)" cause they're only $25.00. I'm guessing bulb type is 9006 for headlights but is it different for fogs?
Old 04-01-2010, 05:28 AM
ZMan's Avatar
Re: HID fog lights
Guess you were too tired to Google: Headlight application guide
1995 SUBARU SVX
Low beam headlamp
9006
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
1156
Tail light
1157
Stop light
1157
High mount stop light
Assembly
Fog/Driving light
H3-55W
License plate
168
Back up light
1156
Front sidemarker
1157A
Rear sidemarker
168
Glove box
194
Map light
DE3175
Dome light
158
74
DE3175
Step/Courtesy light
74
Trunk/Cargo area
168
Instrument-general
158
74
___________________
