Old 03-08-2010, 04:53 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Problem
I don't know how long it's been like this but my drivers side car door unlocks just by turning it. Even with another key or a screwdriver.. what can I do?
Old 03-08-2010, 05:22 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Problem
Install a new lock cylinder.
If you have a keyfob it shouldnt be too much of a problem to have a different key for the driver door.
Old 03-08-2010, 06:30 PM
92 SVX 92 SVX is offline
Re: Problem
you can even have a locksmith rekey the tumblers to match your existing key.
Old 03-08-2010, 07:22 PM
IceBlade's Avatar
Re: Problem
Hm alright, thanks.
Old 03-09-2010, 11:32 AM
gbianchi gbianchi is offline
Re: Problem
Keep that info secret, If no one else knows no prob. I have a wagon that the key broke off in the door just left it and use the broken key...........G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 03-09-2010, 12:03 PM
sowise sowise is offline
Re: Problem
I was thinking similar to gbianchi ... like shhhh if no one knows then it isn't a problem.
I have one SVX where one key does all and then I have another SVX that requires 3 keys. The one I am fixing up is the one with 3 keys so I am contemplating stealing the locking cylinders and ignition from the car that matches the single key. Extra work and a PITA but probably worth it in the end.
You will have to remove your interior door panel to gain access to the lock cylinder and then you can get it worked on or replaced (your call, your $$). While you have your door panel off though would be a great time to do some sound deadening and replace that old plastic inside the door with Dynomat or similar product.
