Old 08-13-2002, 03:09 PM
lee lee is offline
MoreIBNR - it's my second Norton, this one is a 1975 850 Roadster. Many years ago had a '72 model (stolen)- before that a 69 Honda 350 (totaled), there's more but...
I buy lots of Wal-Mart stuff - think it has anything to do with my wife being a manager?
Apology to many readers as this reply properly belongs in babble, but didn't want to start a new thread
Old 08-14-2002, 06:03 AM
mattski mattski is offline
I was a bit puzzled by the WalMart oil filter recommendation for the SVX. Whereas Fram lists the same filter for the 97 SVX and 95 Legacy, WalMart only lists theirs for the SVX and nothing for the Legacy.
Can anyone shed some light on this anomaly and possibly confirm what the correct filter number is?
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 08-14-2002, 09:49 AM
I use SVX filters on my Justy
(they are a little bit larger)
Old 08-14-2002, 07:59 PM
red95svx
The stock SVX filter is slightly different than the stock Legacy filter, but either one will work and most aftermarket companies use the same filter for both applications.
And correct me if I'm wrong, but if you had an oil filter with a bypass valve couldn't you feel the oil filter after you're done driving and see if it is hot? If it was, you'd know that oil is still being cleaned and not bypassing a "full" filter wouldn't you?
David
Old 08-15-2002, 06:13 AM
Thanks for the sizing info.
I would think that as the filter starts to clog, bypass would occur under hard acceleration when demand for oil is greater, but the valve would close under low demand conditions. Feeling the temperature of the filter might then give you a false impression that everything is ok.
Mattski
98 Outback 180k
Old 08-15-2002, 06:13 PM
MoreIBNR MoreIBNR is offline
Original Owner 1992-2008
Send a message via AIM to MoreIBNR
I cannot imagine any filter clogging under anything near normal circumstances such that the by pass valve comes into play. I don't think this would ever happen if you change oil and filter regularly unless something is drastically wrong.
Old 08-15-2002, 06:30 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
David
The oil filter would get just as hot without oil flowing through,just from heat soak from the engine.
Old 08-16-2002, 09:24 AM
red95svx
Yeah, you're probably right.
David
