Old 12-29-2009, 01:24 AM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
Glove box light is on
One little question... when the headlights are on, my glove box light is also on, whether it's open or closed. (I can see the light leaking when closed) Is this normal??
Is there any sensor or switch to turn off the light?
Thanks in advance...
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 12-29-2009, 08:23 AM
Re: Glove box light is on
According to the FSM wiring diagram, Section 6-3, pg.56, the glove box light is controlled by a switch.
Look closely around inside the top of the glove compartment. It could be loose and have peen pushed back to where the glove box door does not contact it completely.
With the ignition on and running, the current draw from the bulb is negligible. When the ignition is off, the power is cut and there is no chance of draining the battery.
Anyway, here is the parts diagram. Switch is #10 at the bottom lef.
The part number is 83091GA021
and is about $15.00 new. Check around here for someone who is parting out cars.
Old 12-29-2009, 12:01 PM
SubaRyu's Avatar
Domo Arigato
Thanks! I will look closely later today.
I did take the glove box compartment out to clean up the evaporator core last summer. Maybe I didn't put the parts back properly...
-Ryu
Links:
[SIGPIC][/SIGPIC]
