forester radio
anyone know if a radio from an02 forester will fit? it's a p122 cd/cass. thanks dennis happy holiday's to all
Re: forester radio
post a picture of it dennyo i got a cd-cass player from an my03 outback or lib the other day and got it hooked up in my corolla was easier to do then i thought it is just smaller then standard double din i think but the vol control knob may not fit behind the svx door unless you shave the back of the door
im not sure if you can see the pic , but does it look like this one http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWNX:IT i only had 3 cms of wiring to work with but used this site to work out which wires where which http://ae64.com/WRX-pinout.htm |
Re: forester radio
hope this helps i'm not good at this. don't need the box just the components
Re: forester radio
not a very big pic
Re: forester radio
hmm its a bit diferent then the one i have is that a pocket thing underneath it it looks like its 2and a half din all up yeah it should fit with the pocket removed
uuhhmm what do you mean "just need the components"? |
Re: forester radio
It will physically fit, but has a different plug for the wiring harness.....there is a member on here that sells an adapter to make it a "plug and play" deal....
Re: forester radio
Huck's talking about "svxdc"
Re: forester radio
aust92 just the radio and cd deck not the box underneath. huck, i crossed the pin-out for the wrx-svx dave sells and they appear to be the same.i have that harness from dave. i currently have a wrx h/u in now. i wanted to be sure it(forester h/u) wasn't to deep for the svx
Re: forester radio
Yep to the best of my knowledge all Legacy/Forester/Impreza use the same pin-out, only the SVX has the odd ball one, which is basically because it was offered in some markets with steering wheel controls, so it needed more pins
Re: forester radio
The best looking/fitting one I found was out of a 03 Legacy GT. It was the midline model 6 disc changer. Looks like it almost belongs in there (green background lighting and similar button shaps and the controls are high up to not interfer with the door. If you do a search you can see what it looked like in my old car.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
