Old 08-06-2002, 01:28 PM
RSVX RSVX is offline
Network Design Administrator
Lightbulb Little Bolt Holes in your rotors...
Well, I know that there has been a lot of discussion on bolt size, thread depth, etc... So here is the answer.
The bolt that you remove to rotate the caliper up to gain acces to your pads just so happens to fit PERFECTLY as I discovered today while installing my ART Rotors. Since some can tend to be very tight, I would suggest ordering some extras so that you dont strip the ones that hold your caliper down...
Hope this helps, it certainly helped me!!
Life is a game. Play to win.
Old 08-06-2002, 02:52 PM
Green1995SVX
wow thanks!!
-Mike
Old 08-06-2002, 07:09 PM
dart
Re: Little Bolt Holes in your rotors...
The bolts that hold on the radiator clamps will work as well. Best to match them up with higher grade (harder metal) bolts at your local hardware store. The radiator clamp bolts tend to strip a bit whilst cranking the rotors off. But it will work.
Old 08-06-2002, 07:24 PM
svx_commuter's Avatar
Cleaning the rust off the hub with some fine emery paper helps too.
Old 08-07-2002, 04:30 AM
FlagstaffSVX's Avatar
FlagstaffSVX FlagstaffSVX is offline
Jedi Member
Like I just posted in the other brakes thread, blow torches and thermal expansion work great together to get the rims off your car. Just heat the center a bit and they slip off like a glove.
-Craig Lowthorp, Flagstaff AZ
'92 LS-L, Black on White, 136k SOLD
'92 LS-L, Black on Silver, 120k SOLD
'01 Legacy Outback, White,
Old 08-07-2002, 11:37 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
8mm x 1.25 pitch and whatever length is what you want. I thought that was covered earlier. This size covers almost all foreign cars that have the same threaded holes.
Old 08-07-2002, 09:15 PM
yeah, thread pitch this, 8mm that, I named an actual bolt that fits it...
