Old 12-03-2009, 04:48 AM
sowise sowise is offline
Need help after engine reseal and cam install
It has been a while since I pulled the engine apart because I have been waiting on parts orders to get it back together.
Here is my problem and question, for the most part I believe I followed the manual when removing the valve covers, intake and exhaust cams, and heads. I did the left side first. What I remember before taking it apart was I had all my timing marks aligned, I don't remember if I did anything to the left side when removing i.e. rotating cams to a different position. When I installed the cams the slots on the end of the shaft and the cam marks were lined up as per the manual (aimed downward). Everything went together fine. I can put the pulley on the exhaust cam and my timing marks are lined up.
The right side was then removed and installed with the cam shaft slots aimed up and the alignment marks as per the manual. At this point is where I get confused. When I mount the pulley it does not line up with the timing marks. So did I do something wrong? I must have missed a step or been in a hurry. Do I have to take one or both sides apart? Can I or should I even try to rotate the crank? I don't want to damage anything but this is where I am stuck and now I have all my parts for reinstall just waiting....
Old 12-03-2009, 03:00 PM
Re: Need help after engine reseal and cam install
Bump.... I am hoping to keep this from falling from view since I could use the help still.
Old 12-03-2009, 05:03 PM
No the pulleys do not match the cam marks. As long as you had the notches for the pullies the same way Ex. cam up intake cam up.... visa versa it will be ok
Old 12-03-2009, 05:05 PM
gbianchi gbianchi is offline
Not real familiar with this job on the svx, but on a 2.2 there is no way to mount the pully wrong, the timing marks on the gears may in fact not have to line up with the pully as the pully has its own marks for timing with the crank, clear as mud?? Sorry I'm not more help, there are others who should chime in..................G
oooh typing at the same time
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 12-03-2009, 05:31 PM
kwren's Avatar
kwren kwren is offline
I believe the cam shafts make one revolution every time the crank shaft makes two. if the cam pully markes and crank all line up, wrong can't happen.
Keith
Old 12-03-2009, 06:28 PM
Thanks for the responses so far, so with the left side pully mounted it is lined up with the Timing marks and the right side pully mounted the pulley timing marks don't line up on that side yet the crank and the left side are lined up. So if I rotate the crank would that move all the positions at the same time so either the right side will never line up with the crank and left side cam pulley or it will slowly rotate into position with the crank and left?
Last edited by sowise; 12-03-2009 at 06:33 PM. Reason: referenced the Timing marks not pulley to cam markings
Old 12-03-2009, 06:30 PM
No, just rotate the R/S pulley to line it up. Install the belt and your are done
Old 12-03-2009, 06:38 PM
Thanks Tom I will give that a shot I was worried that all rotation had to come from the crank.
Old 12-03-2009, 06:43 PM
No, feel free to turn the cams as much as you want. it is a non interference engine so at no point can the pistons touch the valves
Old 12-03-2009, 08:02 PM
Yep that was it I was being overly cautious and didn't want to force the right side to turn without knowing it would not mess anything up. Thanks!
