Old 11-29-2009, 10:10 PM
Elliott's Avatar
Elliott Elliott is offline
Let's play: Guess the electrical gremlin in the Gremlin!
Ok, I have a 1975 AMC Gremlin, all original, 232 straight 6, not even 40,000 miles on it. A few nights ago, I was driving home from a friend's house, alternator died (showing 12.6 volts at the battery when running), made it home, charged the battery and changed the alternator the next morning.
First replacement alternator charged the battery fine at 14.7 volts, but the ALT light was staying on when running, but was off when the car wasn't running but had the switch on, which is also not right. I took it back and had it tested, and the diode pack was bad out of the box, no big deal, it happens. Got the replacement.
Second replacement also charges the battery fine at 14.7 volts, but the ALT light is still acting the same. It tested fine though at the store and is definitely not the problem.
A few more very important clues:
I noticed my gauges are reading low and the BRAKE light in the cluster, which is supposed to come on along with the ALT light when the switch on and engine off, isn't coming on either. If I start and stop the engine a couple times, I can occasionally catch a little flicker of the BRAKE light just as the engine starts.
This is a simple Delco 10SI 3 wire internally regulated alternator, one big wire goes to the battery for charging, one goes to the idiot light and one goes to the ignition switch for voltage sensing.
I have already solved this, and I feel extremely stupid now, lets see who can guess the problem.
Old 11-30-2009, 05:46 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Let's play: Guess the electrical gremlin in the Gremlin!
I'll bite, the exciter wire was pinched in the brake pedal. and were and the pics of this beast?
Wanted: Steering Wheel
Old 11-30-2009, 05:59 PM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
The idiot light wire from the alt to the dash is in short.
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 11-30-2009, 06:54 PM
Elliott's Avatar
No wires pinched, broken or shorted.
Pictures of it here:
http://s136.photobucket.com/albums/q...t1787/Gremlin/
Old 12-01-2009, 06:04 AM
michael's Avatar
What Potholes ???
Excellent specimen, did you do the restoration? How about a missing woodruff key, pulley spins without turning the alternator?
Old 12-01-2009, 06:56 AM
Elliott's Avatar
Nope, I did it the cheap way, I bought it finished. Really all that has been done is a repaint, which was done about 7 years ago.
Nothing wrong with the 3rd alternator at all, it was charging perfectly.
Old 12-01-2009, 07:58 AM
MadMaxSvx's Avatar
Geez... then is a real gremlin messin up with your car!
Btw, nice restoration. Is that an inline six?
95´ Subaru SVX EURO
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
69' Mustang Hardtop
Old 12-01-2009, 05:11 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Do you have a diode/transister thingie in the line going to the gauges like my TVR is supposed to have?
Why don't you come diagnose its charging issues since your a gremlin master! The prince of darkness won't stand a chance!
Old 12-01-2009, 06:11 PM
Elliott's Avatar
The voltage regulator? It has one, but it was fine.
Does anything say "Lucas" on it? If it does, you have found your problem.
Old 12-01-2009, 07:33 PM
subeman90's Avatar
Soobologist
we had a 74 Gremlin X (orange and yellow) with just an AM radio and no AC when I was a kid. i always loved the "remove the key while it is running" trick.
subscribe for answer
15 OBW premium w/eyesight
Old 12-01-2009, 07:42 PM
michael's Avatar
What Potholes ???
Key related?
Old 12-01-2009, 08:13 PM
Elliott's Avatar
Yeah, those old GM ignition locks get worn out quick. Mine was messed up just from sitting for years with the key in it, the tumblers froze in place so a key wasn't required when I bought it. Luckily those locks are available almost anywhere, since it is just a GM part, they are also dirt cheap.
Key related?
Nope.
Think simpler, much simpler.
Yep, just a 232 inline 6 with a tiny little 1 barrel carburetor, maybe 100hp on a good day. Plenty of low end torque though. This is the same design as the famous Jeep 4.0L that they used all the way into the 2000s. Makes for a great daily driver and with a 22 gallon tank, I see a gas station about once a month.
Old 12-01-2009, 08:35 PM
michael's Avatar
What Potholes ???
Disconnected battery <
Old 12-02-2009, 11:06 AM
benebob's Avatar
No a diode resitor pack in after the idiot light before it goes to the other items on the circuit.
Yes there are plenty of Lucas parts on my TVR. All of those have been issue free suprisingly.
Old 12-02-2009, 11:08 AM
MadMaxSvx's Avatar
Oh, of course..! You switched the wires in the alternator, thats why the light remained off when engine off but swith in ign position, and on when engine running.
95´ Subaru SVX EURO
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
69' Mustang Hardtop
